my tail light is foggy and has water drops in them
Old Jul 1, 2010 | 03:38 PM
khalid's Avatar
khalid is infamous around these parts
hey guys i installed the clear lights kit 6 months ago at the local aston martin dealer . all was fine
the car hast been washed in the past couple of days and it was parked underground but its really humid here .
this morning my rear left tail light was foggy and had water drops in them . is this normal what to do ?
Old Jul 1, 2010 | 04:32 PM
tx2900's Avatar
tx2900 is infamous around these parts
Same issue on my 2010 ordered with clear lights. I'm going to try and get by the dealer tomorrow and let you know what they say.
Old Jul 1, 2010 | 04:51 PM
telum01's Avatar
it isn't normal (well, shouldn't be). it means that the casing isn't sealed properly and it is letting moisture in. should be replaced under warranty.
Old Jul 1, 2010 | 04:57 PM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Others have noticed the same phenomenon with the headlights. I don't remember the resolution, but I thought someone said that AM said that it happens and will eventually dry out.
Old Jul 1, 2010 | 05:24 PM
Bus Driver J's Avatar
Bus Driver J is infamous around these parts
x2.
The lamps are supposed to be completely sealed and should not have any signs of moisture in them.
If they have just been replaced, well, they need replacing agin.
Old Jul 1, 2010 | 05:39 PM
druid's Avatar
druid is infamous around these parts
I've had no problems with my clear taillights. Sounds like an issue that would need to be fixed/replaced.
Old Jul 2, 2010 | 01:52 AM
khalid's Avatar
ok so in case i want to replace them my cars warranty expired in april
but the part was installed in march so is iy still covered under warranty as individual part which was new and genuine from AM
Old Jul 2, 2010 | 10:22 AM
telum01's Avatar
i would hope that the parts would be covered under their own warranty, regardless of the age of the car. you should contact the dealer you got them from and ask to have them replaced.
if, for some strange reason, they refuse to replace the part, you might be able to fix it yourself. but i'm not sure where the leak in the housing is. if it's in the seal between the housing itself and the clear "lens" of the light, you might be able to fix it pretty easily. i "cleared" the headlights on my STi (opened them up to take out the amber reflectors) by baking the headlights in my oven to melt the silicone seal, opening them up, then rebaking them to let the silicone melt back into place. depending on how the tail lights are put together, you should be able to do something like that yourself.
i don't think you'll have any issues with getting yours replaced, but i figured i'd mention the DIY repair in case anyone else needs to do it.
COBB Tuning
Jan 1, 2025 09:02 AM
pnoob2
Oct 31, 2015 06:34 PM
Steven997TT
Aug 27, 2015 02:56 PM
