How to remove console fro 2009 Vantage
Old Feb 11, 2011 | 04:59 PM
millsjq's Avatar
millsjq has a spectacular aura aboutmillsjq has a spectacular aura about
How to remove console for 2009 Vantage
I want to run a wire to a switch that I am going to mount in the area of the smokers kit; to activate fuse 22. But need to remove the console. There is a good video on this forum on how to remove the bits for a 2006-2008 Vantage. I have removed the aluminium trim from behind the seat, but can not find a way to remove the rear most leather arm pad. Can anyone suggestion how to do this.
Old Feb 13, 2011 | 10:01 AM
XJRS Owner's Avatar
Don't bother. Just buy the remote-controlled bypass available from West Coast Corvettes. It plugs into the location of the fuse. You get a little key FOB that essentially activates/deactivates the circuit.
http://www.westcoastcorvette.com/p-1...-c6z06zr1.aspx
Old Feb 13, 2011 | 01:20 PM
keitheva's Avatar
keitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of lightkeitheva is a glorious beacon of light
Have you actually tried this and got it to work? I did, and it wouldn't work for me because the way the wires to the fuse are oriented prevents it from fitting into the fuse socket.
adnanm3
Nov 22, 2023 02:43 AM
NIKAS
Aug 20, 2019 07:53 PM
markj
911
Apr 7, 2016 05:44 PM
HotRod
Sep 10, 2015 07:17 PM
manipou
Sep 2, 2015 12:42 PM
