Sport Shift Clutch Re-Learn
Old May 25, 2011 | 12:14 PM
fohguy's Avatar
fohguy is infamous around these parts
Are any of you fine folks familiar with the clutch re-learn process for our Sport Shift cars?
Old May 25, 2011 | 04:13 PM
alevine's Avatar
alevine has a spectacular aura aboutalevine has a spectacular aura about
Yes. On my 2007 SS the procedure is as follows;
From cold engine and with the air conditioning turned off, foot on brake and start the car, hold brake for 10 seconds or so until you hear the clutch 'click'. Switch off and then repeat the process 3 or 4 times.
Pretty simple. It helps reduce some of the slow speed juddering.
Adam
Old May 25, 2011 | 07:38 PM
fohguy's Avatar
Thanks Adam. I'll give it a go.
Old May 26, 2011 | 02:39 PM
LotusJPS's Avatar
LotusJPS is infamous around these parts
I'm curious, what does the learning process do?
I've only had my car a week, though haven't noticed any juddering.
Old May 26, 2011 | 02:46 PM
alevine's Avatar
As the clutch wears it sometimes helps to re-set and/or adjust the catching point. I wouldn't do a thing if there is no juddering.
Adam
Old May 28, 2011 | 10:33 AM
DrScoles's Avatar
DrScoles has a spectacular aura aboutDrScoles has a spectacular aura aboutDrScoles has a spectacular aura about
Stuart, does this still work if you have the RSC TCU upgrade?
Old May 28, 2011 | 06:16 PM
alevine's Avatar
I have the RSC TCU upgrade and still do the clutch re-learn procedure.
Marcos AMV8
Dec 18, 2015 06:03 AM
pshep138
Sep 1, 2015 09:45 AM
orbelo
Aug 30, 2015 12:26 PM
MAcarbon
Aug 19, 2015 04:52 PM
