trickle charger
Old Jul 18, 2011 | 06:02 PM
badpea(o(k's Avatar
badpea(o(k is infamous around these parts
trickle charger
I live in the philadelphia and I recently purchased my v8V. I drive about once a week. When should I think about using my trickle charger? I was told I need it only once it get's colder, in say October. What does everyone else do up here in the north east?
Old Jul 18, 2011 | 09:52 PM
macksamus's Avatar
macksamus is infamous around these parts
Congrats on your recent purchase. Regardless of the weather, I believe it's a good idea to use the battery conditioner (i.e., trickle charger) whenever your car is not in use (unless your car serves as your daily driver). It will help to prolong the life of your battery. I do recall a few threads talking about this....you might wanna run a search.
How about some pics of your V8V?
Old Jul 19, 2011 | 12:13 AM
kba's Avatar
kba
kba is infamous around these parts
There are some threads on this topic, which is how I learned a bit about it. I use my car a couple times a week so I've never used it until recently, as I am out of town for about 2 months.
Old Jul 19, 2011 | 12:40 AM
gekko's Avatar
gekko is infamous around these partsgekko is infamous around these parts
If your car sits stationary for two weeks plus, always a good idea to use the trickle charger. As Macksamus mentioned, it's going to prolong the life of your battery.
Old Jul 19, 2011 | 04:54 AM
badpea(o(k's Avatar
Sorry, I am new and should have searched the threads. Sadly, I didn't even think that others would be as clueless as I am. Thanks I will look.
As for photos, i have three up on my wall so far. None are very good. I will work on that.
Brad.
Old Jul 24, 2011 | 12:46 PM
CTP855's Avatar
CTP855 is infamous around these parts
I just purchased my 2007 V8V about five weeks ago, and the service department recommened I use the battery charger if the car was going to sit in the garage for a month or longer without being driven. I live in the midwest and we can have some pretty tough winters. If the weather is bad this winter, and the car is going to sit for long periods, I will probably leave the charger on regularly. For anyone who doesn't have a charger. I would recommend disconnecting the battery cables if the car is going to sit for a month or better. In the winter, don't hesitate to take the battery out of the car, and keep it in the basement, if the car isn't going to be driven. I know it's a hassle, but it will save the battery. Best option is obviously a battery charger/conditioner.
Old Jul 25, 2011 | 12:25 PM
gsrjc's Avatar
gsrjc is infamous around these parts
Do people also press that button in the trunk to shutoff all electronics? I read about this in the user manual so wondering if people have done that as well and if it helps anything.
Old Jul 25, 2011 | 03:27 PM
macksamus's Avatar
i don't believe it's necessary to do that. the batter conditioner on its own is sufficient. you also don't want to go through the hassle of having to reprogram your radio stations etc if you push that button.
Old Jul 27, 2011 | 08:22 PM
gsrjc's Avatar
ahhh.. good point about the radio stations and probably the home link for the garage too.
Old Aug 25, 2011 | 06:39 PM
TomDB9's Avatar
TomDB9 is infamous around these parts
I live in Houston so don't have the same degree of cold weather to contend with that you do. However, If I'm planning to leave my car unused for more than 2-3 days I plug in the charger. Another tip I got from the dealer for caring for the car during extended periods of not driving is to run the petrol level to about 1/8th of a tank and then refill immediately when I drive it. This helps maintain good fuel condition.
Old Aug 25, 2011 | 09:28 PM
gsrjc's Avatar
Does the trickle charger come with the car?
Old Aug 26, 2011 | 08:32 PM
tjf06db9's Avatar
tjf06db9 is infamous around these parts
Yes it does. Ob the DB9 it should be in the trunk in the recess on the right side with the tire inflation kit. Don't know for sure about where it is in the Vantage.
Old Aug 27, 2011 | 04:05 PM
brumma's Avatar
brumma has a spectacular aura aboutbrumma has a spectacular aura about
It's an option on the V8 Vantage.
Old Aug 28, 2011 | 08:09 PM
gsrjc's Avatar
has anyone had issues where their Vantage has trouble starting? and when i mean trouble, it will fire the first time i turn the key but it just takes a little longer for it to actually fire.
Old Aug 28, 2011 | 08:17 PM
gekko's Avatar
Did you mean something like this?
http://www.youtube.com/watch?v=88mD3YpU83g
