RSC ECU now available as flash?
Old Oct 14, 2011 | 07:40 PM
seattle_sun's Avatar
seattle_sun is just really niceseattle_sun is just really niceseattle_sun is just really niceseattle_sun is just really nice
Called RSC about an ECU upgrade. They said that they are now going to be doing them via a flash through the OBD port.
Anyone have any more info about this?
Old Oct 17, 2011 | 11:53 AM
Irish07@VelocityAP's Avatar
Last I heard(recently), you still have to send your ECU in for the programming..and the "flash" is in the works..not available yet with no ETA
Old Oct 17, 2011 | 12:07 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
Wonder if RSC flash will effect any flashs from Aston,
Or if a Aston flash will effect RSC flash
Old Oct 17, 2011 | 12:26 PM
I actually sent an email to Stuart about this just prior to reading this..let you know what he says
Old Oct 17, 2011 | 12:28 PM
AMFixer's Avatar
Oh man you know what else I just thought about, MISFIRE CORRECTIONS, ask him about that too.
Old Oct 17, 2011 | 12:35 PM
that's pcm..they only have the asm flash right now..but even doing an update on the pcm I don't believe will affect the 36-1..there's no change in the rotating mass nor sensors..just parameters like timing and fuel ratio's are played with on a simple universal tune for the engine..if anything just reset the 36-1 and set again via the road test..but I don't think you'll run into trouble..
Old Oct 17, 2011 | 01:12 PM
In 4 years they have never had a problem with the TCM update being affected by the Aston update..
Old Oct 17, 2011 | 09:53 PM
AMFixer's Avatar
But I thought he was talking about a pcm reflash?
I have heard about the asm reflash just never had anybody do one. They any good?
Old Oct 18, 2011 | 06:28 AM
Well either way, only reason you'd do a flash is if something was wrong with it in the first place...
..don't know if you've worked on land rover or jag..aston doesn't need any software updates on pcm and tcm like the other do..Remember though custom tunes are just remaps of the orignal..so if there was a glitch in the original then that same glitch might very well be in the remaped tune unless the tuner noticed the glitch and fixed parameter orior to the manufactures engineering even solving the concern with there revised tune..
Old Oct 18, 2011 | 07:49 AM
CRVETR's Avatar
CRVETR has a spectacular aura aboutCRVETR has a spectacular aura about
This is one of the most perceptive statements ever issued regarding the Aston engine. I wish that more people would realize that an ECU flash is just a redistribution of what you had in the first place, rather than new adds.
+1 !!
Old Oct 18, 2011 | 02:24 PM
vince_1972's Avatar
vince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nicevince_1972 is just really nice
Better to criticize when you know about it. I had a preparation of ECU Stuart (RSC) for two years and I've never had a problem or a witness light (the grey vantage) . Just more power and pleasure.
Old Oct 19, 2011 | 07:15 AM
Stuart Dickinson's Avatar
Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !Stuart Dickinson Is a GOD !
Yes, we will soon be offering the ECU reprogramming via OBDII - each customer will recieve a hand-held which will allow you to read and write to the ECU, as well as read/clear DTC codes.
TCU will still be via bench for the time being.
Old Oct 19, 2011 | 07:27 AM
+1 !!
You're absolutely correct. ECU remapping is not a re-invention of the wheel. It is a few small changes made within the existing architecture of the ECU. For example, as has been mentioned elsewhere, the AM N400 power upgrade produces 10BHP from the intake modifications, and a further 10BHP through changes to the ECU (actually, just one change - allowing for ignition advance in the presence of adequate octane fuel.)
Is it such a stretch to think that a lowly company like RSC might have the ability to do the same thing as AM and produce a 10BHP boost through the same changes? That's not the only change that we make to the ECU, but why is it that an AM ECU upgrade that does this is the dog's danglies, and if RSC does it, it is 'just a remap of the original'?
Old Oct 19, 2011 | 07:56 AM
hehe..cause in there AM brochure it writes "Upgrade"..so we have to believe what we read..no?? lol..
Old Oct 19, 2011 | 09:30 AM
AMFixer's Avatar
lol.....
