Vantage engine stalling !!!???
Old Dec 6, 2012 | 11:20 AM
  #46
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
misfire adapt procedure attached.
If you have ECU access, modify dashpot decay rate for stall when coming to stop.
File Type: pdf
Old Dec 6, 2012 | 11:33 AM
  #47
Irish07@VelocityAP's Avatar
It's amazing how many cars I get from other garages that can't figure out whats going on..engine is misfiring and there is no check engine light lit..they spent hourrrss diagnosing and finally give up and send us the car..I run my AMDS and find out the corections aren't stored..run the road test to relearn them and bingo misfire on cyl X....pay me know or pay me later..LOL
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Dec 6, 2012 | 01:58 PM
  #48
rmrmd1956's Avatar
AMDS costs a mint as you know. Most OBD testers don't show these custom PIDs but FoCOM from http://www.obdtester.com/focom does a great job for just a couple hundred bucks. It has been customized at my request to work on the AMV8 platform.
Old Dec 6, 2012 | 02:05 PM
  #49
That looks awesome..but do I see that right, there's a Hex editor? hehe..little more than just a DTC and datalogger program ..might be worth me looking into
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Dec 7, 2012 | 08:40 AM
  #50
Aston.Ca's Avatar
Aston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really nice
Wish I had some way of reading out whether the misfire corrections were relearned when I use that procedure. It's tough to find a stretch of road were you can do three succssive 110-45 kmh acceleration/coast cycles without touching the brakes. I occasionally still get stalls when decelerating (only seems to happen when the car is well warmed up - a couple hours of spirited driving for eg and when I'm coasting at low speed, for e.g. with the clutch depressed, foot off the accelerator heading to a red light). Fortunately the starter button has never let me down in situations like that but it's annoying when it happens.
I'm pretty sure I've done a successful relearn but again, have no way of confirming that wo a trip to the dealer.
Old Dec 7, 2012 | 09:13 AM
  #51
rmrmd1956's Avatar
The correct OBD2 reader will tell you if misfire adapt is learned or not plus a lot more.
Old Dec 9, 2012 | 12:22 PM
  #52
Aston.Ca's Avatar
Ok thanks. I received one from RSC to download/upload tunes. What do I look for to determine whether this reader will do the job?
Old Aug 16, 2013 | 07:17 PM
  #53
Mark8V8's Avatar
Mark8V8 is infamous around these partsMark8V8 is infamous around these parts
Does anyone have the fix for the stall issue? Today, mine stalled while approaching a red light, clutch pedal depress and in neutral. Engine just shut off. I restarted and it was fine. Car is a 2013 Vantage manual. Seems others in this thread have the same issue.
Thanks Mark
Old Aug 17, 2013 | 10:36 AM
  #54
cshsia's Avatar
cshsia is infamous around these parts
Thanks Mark
Was it hot when it happened? Also what color is your car?
For me it only happened on two days when it was over 95 degrees and stop & go traffic.
Old Aug 17, 2013 | 11:14 AM
  #55
Mark8V8's Avatar
No it was 8:30 PM and 64 F outside. I have heard some relief but not always the same fix. Some claim a software update resolved it and some claim the fix is a new vent line leading from the gas tank to the engine. My car was built in April 13 so I doubt there is a vent line issue.
Mark
Old Aug 17, 2013 | 12:18 PM
  #56
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Thanks Mark
A friend 2013 S did something similar apparently the dealers and factory are aware of an issue which they have a fix for.
Sorry to be vague that's all I know
Get it to your dealer
Old Aug 17, 2013 | 02:25 PM
  #57
Mark8V8's Avatar
Thanks, if possible ask your friend. I understand maybe a ECU flash may be the fix.
I will contact the dealer to see if they know about this.
Mark
Old Apr 23, 2014 | 05:07 PM
  #58
RicoDB9's Avatar
RicoDB9 is infamous around these parts
Sounds like fuel pressure sensor in the injection system
Old Apr 23, 2014 | 06:41 PM
  #59
karlfranz's Avatar
Rico, you do know that you have been replying to threads that are over half a year old and in some case over 1.5 years old with the same exact reply, right? Or are you trying to build up your message count.
Old Apr 23, 2014 | 06:47 PM
  #60
RicoDB9's Avatar
My message count...lol... I had 12 and I needed 15 to get a private message to Irish re: the Coast Down Procedure. I will post the answer as soon as he replies. Actually I didn't realize they were so old until about 10 minutes ago.
