How much are V8VS Wheels/Tires worth?
Hey guys --
I might be ordering a new set of wheels and don't want additional clutter in my garage (and won't really need a back-up set either). Just curious on what a mint set of graphite 11' V8VS wheels go for with OEM tires (and TPMS) that have about 1500 miles on them.
I was thinking $3k. Too much, too little?
Cheers,
Jon
Cheers,
Jon
Yep add in the fact the S wheels are heavier and 0.5" wider
Good luck selling them for more than $1k on ebay. I had the original and finally got rid of them for $400 after trying many times. Sure the S ones are better, newer, but they are still used and the market is very small.
Esp if you are including the TPMS sensors (missed that in the OP). Those alone will cost you about a grand.
Edit - note however that the TPMS sensors are current cars are not compatible with older models IIRC. Can't recall off hand when the change over happened however from the SmartTire to Beru system (?2011+) so you may want to check with your dealer to find out which ones your module recognizes. Irish? AMFixer?
