Aston Martin battery conditioner
Old Aug 5, 2012 | 10:28 AM
Dr P's Avatar
Dr P is infamous around these parts
Guys my need a battery conditioner, don't want to pay 400$ AM one, I know the cTEK 3300 works with V8V, and fraction of the price?
But they have to connect to the battery and by the cig lighter of the AM, any recommendations on which to get?
Old Aug 5, 2012 | 10:37 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
Order the CTEK 3300 from any internet supplier. Go to Radio Shack and buy the 12V Cigarette adapter. Then cut the battery connectors off the CTEK, connect the red wire to the center of the Cigarette adapter and the black to the ground on the adapter. Then pull the panel from the passenger side trunk area, where the fuse box is, and plug the cigarette adapter into the 12V outlet that is there. Done!
Old Aug 5, 2012 | 11:20 AM
cuemaster's Avatar
cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !cuemaster Is a GOD !
this^
Old Aug 5, 2012 | 11:37 AM
LRDog's Avatar
LRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond reputeLRDog has a reputation beyond repute
Is there not a power connection (12V connection - cig ligther female end?) in the trunk (sorry, boot) like on the DB9?
Ctek is same unit w/o AM logo....
Old Aug 5, 2012 | 02:44 PM
Dr P's Avatar
Is it th e 3300 or 8
Old Aug 5, 2012 | 06:37 PM
MikeD's Avatar
MikeD is infamous around these parts
Get the Ctek 3300 or 4.3 and buy the cigarette lighter adapter. Check the Ctek website or Summit or Ebay. I use the 4.3 with my DBS and it works beautifully.
Old Apr 23, 2014 | 04:47 PM
RicoDB9's Avatar
RicoDB9 is infamous around these parts
With respect to battery tenders, you can buy a fully electronic 2A smart charger for $40 at Canadian Tire... if your patient they go on sale every once in a while for $25. It has a cigarette lighter adapter and I plug it right into the cigarette lighter interface thing in the trunk... works like a jet!!!
http://www.canadiantire.ca/en/pdp/mo...l#.U1hBFF6_fVk
Old Apr 24, 2014 | 03:23 AM
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Battery tips
A couple of years ago, having had good experience with my CTEK, and needing another charger, I called CTEK and learned the model that comes in our cars charge at only a maintenance rate. It was designed for that purpose alone.
The technician advised if I bought a model that included icons for both motorcycle and automobile to use the motorcycle position for maintenance. The cycle charge rate is half the auto rate...the battery would not be stressed/overheated if I used the cycle icon; and it would last longer.
Another time I noticed the tiny light on the Vantage's CTEK was out. It was plugged into the 110 outlet, the red plastic end was secure in the boot but the light was out. I twirled the red plug in its socket and the connection was renewed, the light came on.
Old Feb 19, 2016 | 07:17 PM
yo-lily's Avatar
yo-lily is infamous around these parts
hello sir, do you know how to start 2009 v8 vantage, I tried jump start, but cannot work, I think the battery is dead.
Old Feb 20, 2016 | 04:45 AM
larryg's Avatar
larryg is infamous around these parts
Are you sure that the motorcycle icon charges at 1/2 the rate?
That may even be safer.
I use a CTEK 4.3 for my V8V and R8.
CTEK makes a socket connector that works perfectly with the Aston.
On my 2014 the charging socket is found in the right side of the boot compartment.
Old Feb 20, 2016 | 10:40 AM
telum01's Avatar
I use the motorcycle rate on the CTek I got from Amazon. No issues with it, no battery issues.
I'll be continuing to use it with my lightweight battery, will really put it to the test
EDIT: Looks like the forums are starting to auto-hyperlink ads into text... not f'ing cool
Old Feb 21, 2016 | 04:10 PM
rohnin's Avatar
rohnin is infamous around these parts
when do you guys actually need to use this battery conditioner? i remember going two weeks without starting the car and it was fine
Old Feb 21, 2016 | 07:46 PM
XJRS Owner's Avatar
If you NEED to use it, then I would submit you're too late. I'll just say mine are plugged in whenever the cars are in the garage, 24/7. Don't need the pain that accompanies a marginal battery charge state.
Old May 23, 2016 | 03:48 PM
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
Do any of you just plug the conditioner in to the power port in the console? I just read in the manual they advised to plug it in via the trunk power port, don't know if it makes any diff. Coming from a Porsche I'd only ever had the option of plugging it in to one in the main cabin.
Old May 23, 2016 | 06:37 PM
Jeff_335i's Avatar
Jeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to beholdJeff_335i is a splendid one to behold
I plug mine in via the trunk power port. The power port in my console is gone, replaced with a satellite radio control panel and the power connection now runs my Dension Gateway 500 for the stereo.
