Aston Remote/Transponder or Volvo?
Old Jan 29, 2014 | 07:11 AM
Irish07@VelocityAP's Avatar
Originally Posted by 4leafcloverz
I'm sorry to revive an old thread but I managed to lose the remotes on my '05 DB9. If i buy these:
http://www.ebay.com/itm/OEM-315-MHZ-...07afb6&vxp=mtr
can they be programmed to open the doors and trunks of my car?
Thank you
No, wouldn't work...you need something like a 2005+ S40/S60 looking like this style.. Volvo part# 30772198 (see picture below) ..would require new remote that comes with key codes, if ur shooting for a used remote, and the key codes for a used remote are not given, then avoid it for it's just a useless paper weight and NOBODY has the codes saved somewhere for you to find..don't let the seller trick you
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Jan 29, 2014 | 07:19 AM
4leafcloverz's Avatar
4leafcloverz is infamous around these parts
Found them! Much appreciated. I thought it was ridiculous to buy them at 400 loonies apiece. Will be careful about the codes.
Old Jul 10, 2014 | 03:44 PM
maor's Avatar
maor is infamous around these parts
Just to confirm.
I bought a DB9 2004 with only one key.
If I want to add another key what do I need to do?
Purchase a pair of these fobs 30772198 from Volvo and ask someone with AMDS to program them on?
And then take my key and have it copied so it works in ignition?
Old Jul 10, 2014 | 03:49 PM
Originally Posted by maor
Just to confirm.
The fob is a remote to unlock/lock the doors...the Volvo units will just give you the guts to swap into a fob remote..in no way is this repair a mechanical key to turn the ignition like what your needing for a 2004 DB9
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Jul 10, 2014 | 03:51 PM
maor's Avatar
Damn.
What option do I have to get a 2nd key + 2nd fob then for my Db9?
Old Jul 10, 2014 | 03:58 PM
Damn.
Bluntly..new key and new fob from dealer, there is no other option beside searching the earth for the 2nd key and 2nd fob...you can try using a jag mechanical key blank and have it laser cut to match ur aston key, then programed.to the PATS module by the dealer...and then buy the Volvo remote and program it for the doors..but it would look so ghetto, the Volvo remote is also a key for the ignition of a Volvo car, Google and compare that part number to ur remote..unless you just wanted a backup in your house then I guess that ghetto option is ok..eBay options I wouldn't suggest being they need to supply the key ID number or else it's just a high priced paper weight
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Jul 10, 2014 | 04:02 PM
maor's Avatar
It's only a backup key.
Why does the metal key need programming? Does it contain some sort of transponder?
I always thought this was in the big fob thing and only that need programming?
IS this the jag key ur on about
http://www.terrysjag.com/product/HJD7230AA1.html
Old Jul 10, 2014 | 04:07 PM
Yes that's the key...there is a chip in the key, you don't need a fob to unlock the doors, the key will turn the lock barrel and unlock the door, the PATS will detect the chip in the key and not set off the alarm..but the dealer will need to add the key to the PATS alarm module..aka programming the chip in the key to the car
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Jul 10, 2014 | 04:08 PM
..be aware I've never tried a jag key, but it's the cheapest option I can think of to try
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Jul 10, 2014 | 05:23 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
I actually prefer the older syle machined keys with separate fob. I enjoy putting the key in, turning it then watching the start button light up red before I push it to crank the engine. So much more sense of occasion then shoving a key I to the dash (which cannot attach other keys to it and can easily fall out of pocket.
Most of the body electronics are Volvo (SRS module is perfect example). Most of the engine Electronics are Ford (aka mustang engine).
Yet somehow Aston miraculously manages to create a car far greater than the sum of its parts.... Such is the charm that only Aston Martin can bring
Old Dec 26, 2014 | 04:59 PM
Hocdoc527's Avatar
Hocdoc527 is infamous around these parts
Can someone please tell me what the black small rectangle switch is at the end of FOB opposite end of leather strap? Thanks for the help.
Old Dec 26, 2014 | 05:23 PM
spyder997s's Avatar
spyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to beholdspyder997s is a splendid one to behold
As far as I know, it doesn't do anything for your Aston.
After taking it apart and comparing with the Volvo remote above, you'll notice it's the same remote but with a leather back and the top chopped off. In the original Volvo remote, it held the metal key and would serve as a release of that key.
Since the "aston" remote has a leather back and doesn't have a metal key to hold, it does nothing.
If you have an Allen wrench, open it up and check it out. You'll be disappointed. So ghetto rigged... It only made sense to me after I compared it to the original Volvo version above.
Old Jun 13, 2020 | 05:26 PM
alsr71's Avatar
alsr71 is infamous around these parts
Hello.
Do any of you guys know what type of transponder chip does a 2008 Vantage V8 key uses? 4C or 4D60?
I would like to make a custom key fob with the key part being integrated to the remote. I found that Jaguar X type key looks very similar.
https://www.keylessentryremotefob.co...hoCH44QAvD_BwE
I wonder if the transponder is the same type if the AM dealership will be willing to program it to the car once I have the key made.
Old Jun 14, 2020 | 01:10 PM
J doubleU's Avatar
Possibly the 4D60 as it looks the same. If you have 2 keys already (which every owner should) you can attempt to program the key part yourself as it's a self learning system. Provided you have 2 programmed. The FOB portion is the dealer part.
Old Jul 27, 2020 | 06:13 PM
alsr71's Avatar
Thanks for your reply J double U. I was able to purchase a Crystal Key and swap the internals now I have a fully working remote FOB.
I now have a 3rd key and are about to program the PATS to the car. Do you know the sequence?
