Tail light condensation
Old Jul 30, 2016 | 07:40 PM
  #31
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
I'm having mine replaced under warranty next week... Known problem for a decade... I'd try complaining to a dealer to see if they could at least cut a deal.
Old Jul 31, 2016 | 08:16 PM
  #32
nittany's Avatar
nittany is infamous around these parts
I went through a brushless car wash the other week and my right tailight has condensation. It's been almost two weeks and it's still there with this crazy heat. Do I need to take it out and drill a hole in it or will it eventually go away?
Old Jul 31, 2016 | 08:46 PM
  #33
shootermcgav1n's Avatar
shootermcgav1n has a spectacular aura aboutshootermcgav1n has a spectacular aura about
very disappointed w/these. guy i bought the car from purchased a set of clears last october, when i bought it from him back 2 months ago 1 already had this issue. luckily the dealership took care of getting me a replacement, but this being an issue after only 8 months is just unacceptable for lights that run $750 each.
Old Aug 6, 2016 | 04:53 PM
  #34
Cloneman315's Avatar
Cloneman315 is infamous around these parts
I pull out the taillights when I wash it...
Old Aug 7, 2016 | 01:39 PM
  #35
nittany's Avatar
Is there a DIY on how to pull out the taillights?
Old Aug 8, 2016 | 03:31 PM
  #36
nittany's Avatar
Thanks for the link.....I have a '12 V8 Vantage. I need to remove the right taillight and saw only two screws (one with a black metal dome and one in the side panel). I tried to remove the taillight but it was still caught on something. I am missing something? I look all around and couldn't find a third bolt.
Are the '12 taillights different than the '09?
Originally Posted by messar
Old Aug 21, 2016 | 05:20 PM
  #37
nittany's Avatar
I only see two screws (one with black cap and one inside of the fuse panel). I'm I missing something?
Originally Posted by BMW-North
I don't believe there's any difference since I bought a brand new set for a MY15 (manufactured 2014 by Magna in Toronto, Canada) and fit them into my 06MY. I recall there being three fasteners holding them in.
I only see two screws on the right taillight
Old Aug 22, 2016 | 06:46 AM
  #38
nittany's Avatar
I only have one black cap....I have a 2012 V8V
Here is an image from my car - there are the 2 black caps that need to be removed (just by hand), then the 3 nuts from the studs.
Matt
Old Aug 22, 2016 | 07:44 AM
  #39
Prefurbia's Avatar
There is a bolt missing which happened to me so I took out the bolt on previous light and inserted in new
Old Sep 25, 2016 | 05:02 PM
  #40
K9COP's Avatar
K9COP is infamous around these parts
Has anybody done a thread on removing the lens from the light assembly? I can't find anything on search, and am going to attempt to have the LED boards remade, rather than swap the whole light out...
K9
Old Oct 3, 2016 | 02:27 PM
  #41
wow, the quality of some of these lights are terrible. I just had the left tail swapped out about 2 months ago, and now the right one needs to be swapped as well. mind you these were purchased only last november...
Old Oct 3, 2016 | 02:53 PM
  #42
telum01's Avatar
K9
The lens isn't designed to be removed. It's a sealed unit and not meant to be disassembled. You can try baking the assembly to soften the seal, though. I've done that to open headlights before.
Old Mar 10, 2021 | 03:38 PM
  #43
8Tech's Avatar
5 Year Member
8Tech is infamous around these parts
Hopefully this might help you guys over the pond.
Old Mar 17, 2021 | 05:20 PM
  #44
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Is it possible of instead of blowing the water out you use a vacuum and suck the water out through the drilled hole?
Old Mar 17, 2021 | 05:24 PM
  #45
MRCW's Avatar
what about using nitrogen?
