Remote Programming
Old Feb 28, 2013 | 05:39 AM
Aerome's Avatar
Aerome is infamous around these parts
Remote Programming
1997 DB7 (USA), anyone know the method of programming an additional remote for mere mortals? Or can anyone point me to the section of the service manual where this ancient secret is revealed? It's an easy task on the Jaguars of that year.
Thanks.
Old Feb 28, 2013 | 07:24 AM
Irish07@VelocityAP's Avatar
Wow..your really making my brain work early in the morning...K
  • insert ignition key
  • hold headlamp stalk switch active(headlamps turned on)
  • turn key to position I
  • flash headlamps 3 times for '97 or 4 times for '98
  • confirmatuib chirp will sound and LED will flash once to indicate "learn mode" by the PATS light
  • press unlock button on each remote, chirp will sound for each remote learnt
  • turn of ignition and a chirp will sound to confirm "learn mode" has finished
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Feb 28, 2013 | 01:20 PM
AMFixer's Avatar
AMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to allAMFixer is a name known to all
[*]insert ignition key[*]hold headlamp stalk switch active(headlamps turned on)[*]turn key to position I[*]flash headlamps 3 times for '97 or 4 times for '98[*]confirmatuib chirp will sound and LED will flash once to indicate "learn mode" by the PATS light[*]press unlock button on each remote, chirp will sound for each remote learnt[*]turn of ignition and a chirp will sound to confirm "learn mode" has finished
Wow that works for DB7 too, I thought that was only for Vanquish...good to know.
Old Feb 28, 2013 | 01:50 PM
Hehe..Jaguar didn't have to much money back then..hense the DB7 with out the skin..every notice when ur doing a heater core/evap, you start thinking about how you did that last Jag..LoL!!
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Feb 28, 2013 | 05:44 PM
CARAIBAM's Avatar
CARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of lightCARAIBAM is a glorious beacon of light
Question
Thanks, would this also works on DB7 V12?
Old Feb 28, 2013 | 06:16 PM
I never tried, but it's worth a shot..somethings telling me you might have to flash the lights 5 times for 2000+...I could very well be wrong though
Old Mar 2, 2013 | 08:10 PM
Aerome's Avatar
Hi, Irish07 thanks for answering my question about programming the remote. I think I'm doing something wrong as I can't get the expected results you listed. If I can ask further, I put the key in the ignition and held the stalk back to activate the high beams. With the stalk back I switched the key to position 1 and then flashed the lights 3 times. No chirp, no light. Tried with the headlight stalk in all three positions and any number of combos, same result including continually holding it back after the flashes and releasing it after the flashes. Tried flashing three and then tried four times. Even tried moving to the next steps with no joy. Never could get that chirp! Can you tell me where I'm going wrong? Thanks much, I really appreciate it.
Old Aug 27, 2014 | 02:25 PM
CARAIBAM's Avatar
I unearth this topic on behalf of a friend with an I6 DB7, he has 2 black keys and the red one(master?),one of the black key dosn't start the car,would someone (Irish????) have the procedure to re code the key?
WheelsupZR1
Oct 20, 2015 08:36 PM
The_Orange
Oct 3, 2015 08:23 AM
panas001
Sep 27, 2015 02:51 PM
