08 vantage coupe how low is it? Worried it will scrape in my condo driveway!
Old Mar 26, 2013 | 05:23 PM
goto35's Avatar
goto35 is infamous around these partsgoto35 is infamous around these parts
My e92 m3 always scrapes when going into my garage in my condo driveway.
How low is the aston? Unfortunately i am about to pull the trigger and im pretty sure it will scrape underneath.
No big deal or what can i do?
Old Mar 26, 2013 | 05:46 PM
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
With my Alfa I use a strategically placed 2x4 that I cut a corner off of
Old Mar 27, 2013 | 03:41 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
Test drive one explain the issue to the dealer and go and try it!
Worked for me.
They are actually pretty good for clearance, it is the plastic air flow disrupters in front of the front wheels that scrap first.
Old Mar 27, 2013 | 07:13 AM
telum01's Avatar
this. if you look in front of the front tires, you'll see black plastic pieces that hang down. they'll scrape on plenty of stuff, but it's nothing to worry about. they scraped every single time on my driveway in GA. just be careful and don't worry about that.
you might have an issue with the nose itself. but as long as the car isn't lowered, you should be fine. mine's lowered and i've been surprised at what i've gotten away with.
if you scrape in the middle of the car, that's a different story.
Old Mar 27, 2013 | 07:19 AM
CarreraS997Blk's Avatar
CarreraS997Blk is infamous around these parts
buy a house that is yours and make a driveway that is low for the aston, boom!
Old Mar 27, 2013 | 09:08 AM
goto35's Avatar
The problem is it usually scrapes in the middle.
Old Mar 27, 2013 | 09:15 AM
CJPatel's Avatar
CJPatel has a spectacular aura aboutCJPatel has a spectacular aura about
I have an E92 335i, and that clears mostly anything compared to my Aston Martin Vantage. I can make it over big speed bumps too, but if you have a passenger you might have to have them get out before going over a large one. And I'm assuming since you scrape in the middle entering a garage which goes underground? The sharpest garage I have been in was this hotel garage which was VERY steep, and I did not scrape at all, just took it slow, and turned into the drops. Hope this helps.
Old Mar 27, 2013 | 10:04 AM
goto35's Avatar
haha..yes thanks. Im working on that in a few years!
Old Mar 27, 2013 | 10:07 AM
goto35's Avatar
Thats great. Mine is a bit speaper and it goes underground. So yea im pretty sure i will scrape especially if your 335i clears.
Old Mar 27, 2013 | 10:42 AM
sunir's Avatar
Use the lowest vehicle you own or find a buddy with the lowest vehicle, do the approach at an angle and check for clearances. The Aston is not the lowest of exotics/supercars... you should be fine in most instances.
Old Mar 27, 2013 | 11:29 AM
that would scare the **** out of me if it scraped in the middle.....yikes! I know what you mean though....i have a 997TT and I have to take everything at a dramatic angel, well that and replace the wonderful ($200) plastic front spoiler ever few years. This is the reason I don't buy the $1200 carbon one
Old Mar 27, 2013 | 01:22 PM
SpeedwareMotorsports's Avatar
SpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to beholdSpeedwareMotorsports is a splendid one to behold
I would talk with the HOA and see if they would be ok with pouring concrete to make the entry less severe, or possibly just putting some 2x4s along the dip to do the same thing.
Old Mar 27, 2013 | 02:01 PM
mikey k's Avatar
The CF lip on V12V & S is near $8k
Old Mar 27, 2013 | 02:15 PM
sunir's Avatar
Use wood, My townhome in the city was brand new and my garage wasn't level graded w the outer pavement until the road was formally leveled and black topped/paved, in the interim I used a few well placed wooden planks and sorted things out just right.
Mikey, 8 grand is way too much for that front cf lip, take it off, have a mold made and have a composites shop lay wet carbon on it then vacuum seal the part...it'll have ya sorted out for beans compared to that 8 grand ya spendin if somethin happens to the front lip there.
Old Mar 27, 2013 | 02:50 PM
Racer_X's Avatar
Racer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud ofRacer_X has much to be proud of
Approaching from an angle also helps.
