squeaky noise ftom under hood!!! V8 vantage
Old Apr 15, 2013 | 09:01 PM
Aston.Ca's Avatar
Aston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really nice
^^^ Rough cost for the air/oil separator O ring/pulley replacement fix?
Old Apr 16, 2013 | 11:38 AM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
Originally Posted by captain Greg
just washed my V8 vantage all was ok when I reversed it out the garage then after washing it I now have squeaky noise seems to be coming fro the fan belt drive train i think..... any ideas from you seasoned V8 owners
your squirrel needs to be replaced
Old Apr 17, 2013 | 08:12 AM
Irish07@VelocityAP's Avatar
The o-ring is about 2 bucks, the idler pulley is about 70, belt is about 90..price will vary from dealer mark-up
Just make sure the o-ring is only thing leaking and not the Y-joint seal (where the head/timing cover/engine block all meet together.) look at the top-outward most 8mm head bolt of the timing cover for both banks, if they're soaked in engine oil..Y-joint seal is leaking also, replacing only the belt will be just a temp solution, noise will come back due to contamination of oil from the leaking Y-joint seal
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Nov 29, 2019 | 07:12 PM
Wildcat1212's Avatar
Wildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of lightWildcat1212 is a glorious beacon of light
Originally Posted by Irish07@VelocityAP
Look at the lower idler pulley(drivers side)..there is an old version and new version of idler pulley. Most of all 4.3L's had the old style round edged pulley. The new style has walls on the pulley to align the belt better for the next pulley in-line to come. If engine squeaked on a cold start and noise went away when warm...9/10 the engine still had the old style idler pulley, fix would be the new idler pulley (standard on 4.7L) and new belt for the new spec pulley..
If the belt squeaked when cold..and did not go away when warm, either belt has coolant or engine oil on it..trace the leak and fix..then replace the belt and idler pulley if it's stil lthe old style...9/10 if this was the case, air/oil seperater was leaking from the o-ring(AD23-3B9623-AA), replace o-ring to delete the concern and wash engine with belt off..dry everything and then fit the new belt and new pulley
Newer belt for newer pulley: 9G33-8620-AA
Newer idler pulley: 9G33-19A216-AA
Is it same for DB9 ? I have 2009 DB9, i am about to replace the belt and pulley, do I replace it with grooved one?
Old Dec 2, 2019 | 09:28 AM
No, not the same at all..
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Dec 2, 2019 | 12:46 PM
Are there any substitute ?
Old Dec 2, 2019 | 12:48 PM
Substitute for the belt on a V12?
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Dec 2, 2019 | 12:53 PM
Whole thing
pulley and belt?
Old Dec 2, 2019 | 01:15 PM
No idea who makes an aftermarket substitute. V12 has 2x smooth pulleys + 1x v-grooved + 1x tensioner. The pulleys are around 30usd each, tensioner in range of 100usd and belt around 80usd. Whether it be a 2001 V12 Vanquish or 2009 V12 DB9, same parts..
However, there's no reason change the pulleys on a V12 unless faulty, just change the belt...
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
Old Dec 2, 2019 | 04:29 PM
thx Irish.
I have grinding nose coming from front of the car when in park mode but goes away when drive mode. I thought I would replace the pulleys and belt but may be I will try the belt first.
BenTT
Jul 22, 2021 02:38 PM
Bmanny
Sep 16, 2015 08:29 AM
dailydriver
Sep 13, 2015 09:01 AM
vchris
Cayenne Turbo
Sep 11, 2015 02:52 PM
