squeaky noise ftom under hood!!! V8 vantage
Old Apr 6, 2013 | 06:55 AM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
just washed my V8 vantage all was ok when I reversed it out the garage then after washing it I now have squeaky noise seems to be coming fro the fan belt drive train i think..... any ideas from you seasoned V8 owners
Old Apr 6, 2013 | 08:07 AM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
Sure its not your brakes dragging? Water on iron brake rotors creates a surface layer of instant rust that will drag onto the calipers and make a squeak for a mile or two. Goes away pretty fast.
Old Apr 6, 2013 | 09:50 AM
It happens while is idling i garage.... I took it for a drive expecting the worst (like leaking water pump or some type of idler pulley) now its gone again? Im a bit paranoid abou thi car after reading obout its reliability issues it has now gor 22000Km on the clock
Old Apr 6, 2013 | 09:52 AM
apologies for the spelling in the last post guys, did not check it nor this one seems like my browser spell check is on leave
Old Apr 6, 2013 | 10:03 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
22000km is nothing! These cars are pretty robust and get better when driven regularly. Don't forget that few owners post on the forums when things are going well (which is most of the time).
Old Apr 6, 2013 | 10:33 AM
makes me feel a bit better, hearing that is low mileage most guys never drive their high end cars,,,they seem to remain ornaments.
My problem is that when i drive i tend to be enthusiastic that said I never over rev or abuse the clutch, in my time with vantage I have only hit the governor twice being drawn into the experience and not monitoring the rev counter
Old Apr 7, 2013 | 01:23 PM
Irish07@VelocityAP's Avatar
U have a 4.3L?
Old Apr 8, 2013 | 12:56 AM
i do?
Old Apr 8, 2013 | 06:30 AM
Look at the lower idler pulley(drivers side)..there is an old version and new version of idler pulley. Most of all 4.3L's had the old style round edged pulley. The new style has walls on the pulley to align the belt better for the next pulley in-line to come. If engine squeaked on a cold start and noise went away when warm...9/10 the engine still had the old style idler pulley, fix would be the new idler pulley (standard on 4.7L) and new belt for the new spec pulley..
If the belt squeaked when cold..and did not go away when warm, either belt has coolant or engine oil on it..trace the leak and fix..then replace the belt and idler pulley if it's stil lthe old style...9/10 if this was the case, air/oil seperater was leaking from the o-ring(AD23-3B9623-AA), replace o-ring to delete the concern and wash engine with belt off..dry everything and then fit the new belt and new pulley
Newer belt for newer pulley: 9G33-8620-AA
Newer idler pulley: 9G33-19A216-AA
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Apr 8, 2013 | 06:42 AM
Irish your a god! i will look tonight and advise appreciate your comments as always
Old Apr 8, 2013 | 08:26 AM
IbisRider's Avatar
IbisRider has a brilliant futureIbisRider has a brilliant futureIbisRider has a brilliant futureIbisRider has a brilliant futureIbisRider has a brilliant futureIbisRider has a brilliant futureIbisRider has a brilliant futureIbisRider has a brilliant futureIbisRider has a brilliant futureIbisRider has a brilliant futureIbisRider has a brilliant future
Yep.
Just had the same issue with my '08 (20,000 mi). Just the olde style pully. Dealer put the new one on and the little squeek is gone.
Old Apr 8, 2013 | 10:03 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
Originally Posted by IbisRider
Yep.
Very common problem, my dealer replaced the pulley and belt and noise is gone.
Old Apr 8, 2013 | 09:12 PM
Aston.Ca's Avatar
Aston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really nice
Thanks dude! What's the rough cost on these +/- the labour? I think I have the latter issue.
Old Apr 9, 2013 | 12:04 AM
any chance of a pic of the newer pullu assembly? mine has a mounting bracket that is squared off at the bottom if viewed from the front the pulley has no walls on it? the one shown in my manual has rounded look ?
Old Apr 12, 2013 | 02:32 PM
From viewing underneith, there is a black metal bracket bolted to the timing cover by to 8mm head bolts(bracket holds a plastic oil pipe in place)..this bracket is inline with the tensioner and the ilder pulley in question.
The manual will most prob show the old style pulley, even if it's the latest 2013 edition(no need to redo photo's for just a pulley)..the rounded idler pulley is what needs to be replaced with the newer wall styled idler pulley
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
www.velocityap.com
