Clicking noise speed related from outside rear
Old Jun 21, 2013 | 05:13 AM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
Been driving the car the other day and I get a clicking noise the faster I drive. It comes from the rear left as far as I can tell.
Doing some googling I have found it to be symptomatic of CV joint failure? But my car has only done under 30,000 miles so is that not a bit premature for failure.
Old Jun 21, 2013 | 07:50 AM
drcollie's Avatar
drcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond reputedrcollie has a reputation beyond repute
Most the time that's a small rock lodged in the tire tread.
Old Jun 25, 2013 | 10:58 AM
Irish07@VelocityAP's Avatar
I 2nd that..the CV axles make the same type of clicking, but the clicking is from the front wheels when turning on a front drive driven vehicle..not your case..
I would hope for a rock in the thread..but suspect a nail, get it checked
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Jun 26, 2013 | 07:57 AM
tko211's Avatar
tko211 is a jewel in the roughtko211 is a jewel in the roughtko211 is a jewel in the rough
EXACT same thing happend to me within 2 days of my ownership experience. I was on the freeway and started to notice a clicking sound the faster it went the louder and faster it became. I pulled off and quickly got onto some surface roads. The noise went away. Also I should note that the car never felt bad or different. It just made a noise.
Later when I got home I got under the car and discovered in an instant what the problem was... Due to really bald tires from the used car deler (not Aston). The entire inside tread near the sidewall was coming apart and I had metal cording that looked like small rope that had come out of the tire and was whipping around inside the tire well. Remarkably the stupid tire held air until the next day when I could limp it to Discount Tire. They had the OEM tires in stock and the total cost for all new OEM rubber was about $800.00 cheaper than at Aston Martin Vegas.
Old Jun 26, 2013 | 09:05 AM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
Sounds like a CV joint failure I had one on my Porsche. Sometimes just taking the joint apart and re-lubing will fix the issue ( had a bad boot let all the grease out).
Old Jun 26, 2013 | 11:28 AM
Vergis's Avatar
Hmmm the tread is low so it could well be the tyres.
However I have checked the tyres and they seem OK. No wires sticking out. May just change the tyres anyway.
Old Jun 27, 2013 | 03:21 PM
Aston.Ca's Avatar
Aston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really niceAston.Ca is just really nice
Check the tire pressure ... is the left rear a little low? That might give you a clue. With wide tires, you really have to have it off the hub to look for a puncture properly. Quick and dirty is to put some soapy water on it and look for bubbles ... but that would likely only work with a tire that is deflating fairly rapidly (which it does not sound like you have).
Old Jun 27, 2013 | 04:19 PM
Vergis's Avatar
Tyre pressure visually seem ok.
Going to get it on a ramp next week I think... Check CV joint and spin the wheels and see if we can trace the problem.
Old Jun 27, 2013 | 08:05 PM
dan87951's Avatar
Check for any damage on the rubber boot. If its got a tear in it im almost certain its the CV joint than!
Old Jul 4, 2013 | 02:23 PM
Vergis's Avatar
Hey Guys
Thanks for all the comments. Had the car on the ramp and the mechanic inspected all the cv boots , linkages, rubbers, tie rod bits etc on all 4 wheels. All are fine. We spun the from wheels and no noise occured. The rear wheels could not move very quickly ( yes handbrake was off ) when spun and when we heard nothing.
Rear tyres are low but no wires sticking out thankfully. I want one more track day out of the tyres first. However the rear brake pads are low to very low which could explain the clicking.
The mechanic doesnt think its a bearing because you tend to get a squeak and that happens especially on turning.
So going to change the rear pads and hopefully report back that all is well again but I do have some great looking Michellin Super Sports in the garage that I am tempted to just put on at the same time.
Old May 21, 2021 | 05:34 PM
rajiggyfizzle's Avatar
rajiggyfizzle is infamous around these parts
@Vergis Bit of a long-shot 8 years later, but on the offchance you see this - did you ever figure this out?? facing a similar issue with mine and can't figure it out.
Thanks!
Old May 22, 2021 | 06:45 AM
8Tech's Avatar
5 Year Member
8Tech is infamous around these parts
To diagnose whether it is the tyre or not, simply swap rear tyres side to side TEMPORARILY, and see if the click changes side.
Sep 1, 2015 03:16 PM
PelicanParts.com
Sep 1, 2015 02:36 PM
New991S
Aug 31, 2015 05:22 PM
gulf gt
Aug 27, 2015 10:27 AM
Rumrunner
Charity Notices/Events
Aug 20, 2015 11:07 AM
