What does a red "H" mean in the gear readout on '13 V8V ASMII?
Subscribe
Aug 11, 2013 | 09:37 PM
It has happened twice at stoplights and caused a slight delay in getting it back into 1st gear. I was in N both times while waiting. I only have 40 miles on the car!
Reply
Aug 12, 2013 | 06:52 AM
No idea. I never saw it with my Vantage S. Did you check the manual and/or call the dealer?
Reply
Aug 12, 2013 | 04:59 PM
It means that Hill Start Assist has been engaged.
Reply
Aug 12, 2013 | 10:02 PM
Thanks V8Vantage. I wasn't really on a hill either time but that makes sense!
Reply
Aug 12, 2013 | 10:14 PM
That's interesting. On mine, it does not engage for minor slopes. It has to be a fairly decent angle. If it came on when you were on a level surface, you may want to have it checked by the dealer.
Reply
Aug 13, 2013 | 01:56 AM
Try doing a coupe of clutch learns with NOTHING else on, it seemed to make my hill assist work better
Reply
Aug 13, 2013 | 09:22 PM
Thanks Mike! Will give it a shot.
However, I thought that clutch learns were not required with ASM2. From pistonheads FAQs:
Sportshift 2 (ASM2) - is a 7 speed updated version fitted to the Vantage S, there is no creep mode and no need to do "learns" it also has hill assist
Reply
Aug 14, 2013 | 04:17 AM
I put that in the FAQ
It does start them automatically when you first start the car (N light flashes whilst doing it)
BUT as with ASM1 it seems to work better if you make sure nothing else electrical is on and you do a couple in a row when you first get it.
Reply
Aug 14, 2013 | 09:38 AM
Cool. Will try it out the next time.
Reply
Aug 14, 2013 | 07:35 PM
It does do an auto clutch learn while the light is flashing, but some drivers avoid this and take off..the car with void the learn and allow u to start rolling...which screws up the clutch learn
Yes H is hill assist, if u are experiencing this often then the vehicle will need to be calibrated by the dealer on a level surface like an alignment machine or levelled 4-post with no weight in the car
Reply
Aug 14, 2013 | 08:31 PM
Is there anything that our Irish guru doesn't know?
Reply
Aug 15, 2013 | 06:51 AM
Quote: Is there anything that our Irish guru doesn't know?
Yah, my wife...can't figure that woman out! ;-)
Reply
Aug 15, 2013 | 10:16 AM
^^^ Lol...
Reply
Subscribe
