H&R Springs confusion... 29108-1 vs 29108-2? Or Vantage S springs
Old Jan 12, 2014 | 02:00 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
Hey guys,
I do want to drop my car, and I do like the idea of a progressive rate spring for a much softer ride. The stock springs are to stiff for cruising, and too soft for performance (worst of both worlds). The only reason I have avoided springs is everyone says H&R drop 1.25 inches (too much IMO).
I know there are two different heights after searching (along with two different part numbers, 29108-1 vs 29108-2).
Many claim the 0.75" drop rating is actually inaccurate and it's really more... Is there a spring that will genuinely just drop the car 5/8-3/4 total? I don't want to drop it too much and most of the H&R drops I see are way too much IMO.
Another option is Vantage S springs which are supposedly a 20mm drop but increased sprig rate. If anyone has a used set of Vantage S springs I would be interested in those as well
Any help is appreciated bc this is confusing
Old Jan 12, 2014 | 02:16 PM
bluebarchetta's Avatar
bluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of lightbluebarchetta is a glorious beacon of light
I'll let others answer your other questions.
However, the difference between the 2 spring part numbers you list is not drop, it's for different cars.
29108-1=2006+ V8 Vantage Coupe
29108-2=2006+ V8 Vantage Vert
Old Jan 12, 2014 | 02:35 PM
Thx for the clarification, that definitely is a good start.
Can anyone confirm the Vantage S spring drop is 20mm? (Close to .75" drop)
Zmydust
Sep 10, 2015 12:31 PM
flewis763
Sep 9, 2015 11:11 PM
midtownlandman
Sep 3, 2015 01:17 PM
