I keep getting a big tangle of metal stuck under my car...
Old Jan 22, 2014 | 10:17 PM
Fubar's Avatar
Fubar has a spectacular aura aboutFubar has a spectacular aura about
I have never run into this issue but it sounds like you are on the right path. If it only happens while moving, during hard left turn then it should be a related solution. Check for some type of debris that would connect with the wheel or rotor during a turn (maybe stuck in the A-Arms).
It can be difficult to tell if a noise is coming from the front or back while in the car but the noise might be related to the differential, only occurring when rear tire rotation is at a maximum difference. In this scenario the temperature of the diff gear may be the 'random' factor.
That was just my observation from the information I read. I certainly don't mean to get you worried about nothing... It's probably just a rock in the rotor.
Old Jan 23, 2014 | 06:08 AM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Originally Posted by rbobby
I had it happen once early on. I thought I broke something serious after a hard turn. It probably was a piece of road debris. I heard something metallic fall out onto the road and the scraping noise was gone. Car was fine since.
It is REAL scary the first time for sure! Yep....got out and looked under the car. No issues since. Thinking back it must have been a rock lodged in the front right break.
Old Jan 23, 2014 | 10:46 AM
V12V's Avatar
V12V is infamous around these parts
I have had the same experience on every vantage I have had. Just happened on the V12. Stopped and looked and nothing. Must be the rock theory!
Old Jan 23, 2014 | 11:58 AM
V12Vantage's Avatar
V12Vantage has a spectacular aura aboutV12Vantage has a spectacular aura aboutV12Vantage has a spectacular aura about
I picked up a stone in mine just shortly after I got it. It cut a lovely deep groove in the rim where the stone was trapped between the brake caliper and the inside of the rim. It also made a serious racket when doing its job !!!!
Old Jan 23, 2014 | 12:28 PM
jroback's Avatar
jroback is infamous around these parts
This thread has become a huge source of relief for me!
Old Jan 23, 2014 | 01:23 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
As Dealers are known to say, "TADTS" (they all do that sir).
BLKMGK
Sep 19, 2015 03:51 PM
albert@velosdesignwerks
964
Sep 9, 2015 11:48 AM
964 Turbo
Sep 9, 2015 11:46 AM
993 Vendor Classifieds
Sep 9, 2015 11:20 AM
Lexus Vendor Classifieds
Sep 9, 2015 10:49 AM
