noisy serpintine belt (fan belt) V8 Vantage
Old Apr 25, 2014 | 12:57 PM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
I know we have had this discussion on here but here goes lad's mine started to squeak like a cricket , and went away when it gets warm (hot) but still annoying co's the car has a wonderful burble when its cold and you start it to pis of your neighbors who drive BWM and so on. So having a squeaking belt on start up is embarrassing
Belt got noisy today, i have not driven it for 6 weeks and got back into my home town turned the key and all i have is chirp chirp chirp even when its hot.
I called AM cape town they cant help till 5th May due to holidays and commitments..
i then put on a 6mm dowel a piece of sponge and soaked it in wyns dash a type of plastic re-newer? and placed this on the belt carefully on the outside while it runs, taking care not to let the fluid fall on the ribbed side.
silent as a mouse - so good for a temporary weekend fix I will see how long it lasts my car has 23000Km on it and goes like a bullet with no issued and I drive it with enthusiasm.
Old Apr 25, 2014 | 06:31 PM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
are you sure it's not a failing bearing in the pulley? AM has a recall for that.
Here's a link to the repair
attached is the AM service bulletin
File Type: pdf
Old Apr 26, 2014 | 01:20 AM
thank you for this, just a question why would the noise go silent if I put rubber enhancer layer on the smooth (top) of the belt as I have done? if it was the pully then the noise would have continued? or am I wrong because i did nothing to the bearing
Old Apr 26, 2014 | 05:12 AM
zvez's Avatar
unless by happenstance some of the lubricant leeched down to the bearing races of the failing bearing. just a thought.
Old Apr 26, 2014 | 10:11 AM
I took it for 1oo mile hard run and the noise is still gone? if it did manage to lube a faulty bearing then by now it should have started to sscream again or am i wrong?
Old Apr 26, 2014 | 12:18 PM
zvez's Avatar
no idea. I do know back in the old days for a squealing fan belt we'd use brake fluid that worked as well.
Old Apr 26, 2014 | 12:25 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
I had an 07 (new) that started doing the same thing a few months after i bought it... The dealer changed out the pulley system under warranty
VID997
97
Mar 20, 2018 02:23 PM
Wheeler
Sep 22, 2015 08:02 PM
NTIMD8
Sep 14, 2015 09:31 AM
h00pak
Cayenne 958
Sep 11, 2015 04:37 PM
oo7
Sep 10, 2015 08:08 AM
