Vantage Twin Disc calibration problem
Old May 5, 2014 | 05:43 AM
Marcos AMV8's Avatar
Marcos AMV8 is infamous around these parts
Unhappy Vantage Twin Disc calibration problem
Hi all!
I have installed a twin plate clutch and doesn´t work. I assumed that the clutch relearn calibrate it but didn´t work and I did it with the AC off, press the brake pedal and turn on ignition, wait for about ten seconds until a "click2 sounds and repeat the operation for 3 or 4 times.
My question is about if the relearn is to compensate the wear of the clutch or also can calibrate increments as when you put a new clutch. In Lambos you need to use the official diagnosis to do that so Im wondering that I have to do the same with the Aston MArtin diagnosis tool AMDS
Go to a dealer is not possible, the problem is that I live in a island in the front of Africa 1300 km by ship far away from Spain mainland so I have to solute this by my own
Old Aug 29, 2019 | 03:45 PM
lilseevs's Avatar
lilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud oflilseevs has much to be proud of
Did this get resolved? I just installed my VAP Twin Plate and the car is driving fine, but am getting a lot of powertrain associated codes. My dealer is the only local shop with an AMDS and they are backed up 3 weeks waitlist, as far as I'm aware on a sportshift it needs to be dealer/AMDS re-calibrated
After x amount of time driving, it will go into limp mode, then exit, then re-enter :/
Old Aug 30, 2019 | 05:33 AM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
Maybe an AM mechanic would like a nice Canary Island working vacation?
Old Sep 3, 2019 | 07:38 AM
XJRS Owner's Avatar
5 years waiting on a service call would be a little too late, don't you think?
mysticwizard
Jan 8, 2019 11:27 AM
Stuart@VelocityAP
Nov 30, 2018 04:13 PM
Jeff_335i
Jun 2, 2018 09:14 PM
dmose
Sep 18, 2014 09:34 AM
Poults
May 8, 2013 06:19 AM
