Break in time....
Old May 19, 2014 | 08:36 AM
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Break in time....
Is there a "break-in" period for the Vantages? Is so, how long, or how many miles?
Old May 19, 2014 | 11:16 AM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
I think its generally accepted to properly break in a steel walled cylinder, its about 1000 miles. I also think a lot of the exotics break their engines in , at the factory to a certain extent.
it would be interesting to hear from someone that knows.
Old May 19, 2014 | 11:22 AM
HenryM's Avatar
HenryM is infamous around these parts
The manual for my V12 Vantage says 1,000 miles.
Henry
Old May 19, 2014 | 09:31 PM
plastique999's Avatar
plastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to allplastique999 is a name known to all
Henry
What does this mean? Not revving beyond a certain RPM?
I can tell you it's damn hard to drive this car slow
Old May 19, 2014 | 09:57 PM
V12Vin's Avatar
V12Vin
I was under the impression that the engine was already broken in at the factory but not the clutch? IIRC, the manual seems to mention something similar.
Old May 19, 2014 | 11:09 PM
karlfranz's Avatar
During the break-in period of 1,243 miles (2,000 km) and/or whenever the engine temperature is below 104°F (40°C) the ECU automatically prevents maximum revs in order to protect the engine.
This applies to both the V8 and V12.
Old May 20, 2014 | 01:52 AM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
They are test run rather than run in for any length of time
Old May 20, 2014 | 10:25 AM
rohnin's Avatar
rohnin is infamous around these parts
I wonder if you also have to keep varying engine speed, too
Old May 20, 2014 | 01:06 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
Follow the manual. Avoid sustained or higher revs. Vary road and engine speed. I was taught that the first 10 km or so are most important, with large throttle openings and plenty of backing off the throttle / engine braking desirable for proper break-in, but I'm no mechanic or engineer.
PV=nRT.
Sep 9, 2022 06:06 PM
Oct 6, 2015 06:13 PM
alpha motoring
Oct 2, 2015 12:04 PM
cabman4007
Sep 28, 2015 03:25 PM
