Where do you stow the owner's manual
Old May 29, 2014 | 07:34 AM
RudyP's Avatar
RudyP is infamous around these parts
The owner's manual for my 2010 Vantage was in the passenger side door pocket when the car was delivered to me (used). I tried to put it in the glove compartment but it does not fit due to its strange long shape. Is it meant to stay in the pax door pocket or am I missing something?
Old May 29, 2014 | 07:44 AM
karlfranz's Avatar
It goes in the glovebox. You just have to angle it a bit.
Old May 29, 2014 | 07:49 AM
jroback's Avatar
jroback is infamous around these parts
Under the passenger seat.
Old May 29, 2014 | 07:51 AM
RudyP's Avatar
I guess I will try the glove compartment again when I get home tonight. Must not have fiddled with it enough.
Old May 29, 2014 | 07:52 AM
telum01's Avatar
Try under the front of the passenger seat. I keep mine there most of the time.
Old May 29, 2014 | 07:55 AM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
As KarlFranz said, you have to angle it a bit--just fiddle around with it. It will go in but it's a tight fit. Then of course about the only other thing you can put in the glove box is a soda straw, but you'll have to fiddle to get that in as well. Not a particularly good design.
By the way, as I recall, if you look closely at the molding on the box you'll find "Jaguar".
Old May 29, 2014 | 09:04 AM
XWCGT's Avatar
XWCGT has a spectacular aura aboutXWCGT has a spectacular aura aboutXWCGT has a spectacular aura about
another crazy thing about the AMV8. really, you have to "angle " it to get it to fit. god forbid you put a pencil or pen in there too! I noticed that the first day with the car, and thought to myself... "hmmmm, 6feet of dash board, and you cant figure out to get a set of gloves to fit in the glove box with the owners manual and auto registration??? that designer should be fired too.
yes, you do have to fiddle with it. angle it . And, put the pen, the lighter (that doesn't go in the lighter hole because my phone charger is there), and your registration behind the manual. it will "all " fit nicely!
Old May 29, 2014 | 09:30 AM
Under PSI's Avatar
Under PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud ofUnder PSI has much to be proud of
The problem I encountered with putting the manual in the glove box is that if the battery dies and you need to manual to find out how the jump start the car, you can't get to it because the glove box door requires power. Guess what else? The battery is behind the passenger seat which is also power, including the back release, and you can't get to the battery either. I keep my owner's manual on the shelf behind the passenger seat.
Old May 29, 2014 | 09:33 AM
karlfranz's Avatar
There is a manual release for each seat back.
Old May 29, 2014 | 09:36 AM
Under PSI's Avatar
Where? Mine has a lighted button on the headrest but it is power only. Mine has dual heated, power, memory seats if that matters.
Old May 29, 2014 | 10:03 AM
zvez's Avatar
zvez is just really nicezvez is just really nicezvez is just really nicezvez is just really nice
when my car was delivered it was in the glove box. The previous owner has his ipad pigtail in there, for the life of me I can't get the manual to fit now because of the pigtail, tho it was there all along! Just keep it in the boot now.
Chris
Old May 29, 2014 | 10:23 AM
AXARUNNER's Avatar
AXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to beholdAXARUNNER is a splendid one to behold
Pull the strap at the top of the back seat (below the head rest)... Put the owners manual under the rear shelf that's behind the seats.
Old May 29, 2014 | 10:57 AM
karlfranz's Avatar
AXA already answered this. All sport seats have a manual seat back release. Doesn't matter if they're heated or have memory. RTFM!
Old May 29, 2014 | 12:30 PM
Under PSI's Avatar
I'll take a look when I get home. I don't recall having seen one. Manual is sitting now on my desk at home as I have had to read it numerous times to find out how to fix all the crap that seems to go wrong on these cars. Must have missed the "here's the manual release for when yet another problem occurs on this car" section.
Old May 29, 2014 | 12:37 PM
mikey k's Avatar
mikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to allmikey k is a name known to all
unless you have light weight seats
In which case you need a booster pack to get to the battery
My manual lives in the glove box correctly angled up at the back
I have a PDF copy and know the "emergency" essentials
