Seat memory Controls
Old Aug 28, 2014 | 01:09 PM
Ron Avery's Avatar
Ron Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to behold
So my 2007 V8 Vantage does not have power seat memory. If I were to buy the control panel for the seat adjuster with the memory buttons would it work to simply replace what I have?
Ron
Old Aug 28, 2014 | 01:29 PM
telum01's Avatar
The part numbers I'm seeing for cabin wiring harnesses only specify RHD vs LHD, manual vs automatic transmission, and with or without tel/nav/PDC.
If that's the case, then I'm assuming the memory seat module will be plug-and-play with your existing harness. I'm basing this entirely off a list of wiring harness part numbers, so take it with a grain of salt.
And then here's these:
7G43-14A701-AC - Switchpack assy, seat, RH - 1 - With memory
7G43-14B709-AC - Switchpack assy, seat, LH - 1 - With memory
I don't know if there's anything else needed.
Old Aug 28, 2014 | 09:09 PM
Ron Avery's Avatar
Thanks for the info, I will check into it.
Ron
Old Aug 29, 2014 | 04:29 PM
Ron Avery's Avatar
Ron
The dealer just told me this can't be done by just replacing the seat controls .
Ron
Old Jan 29, 2018 | 12:27 PM
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Is the "no" the definitive answer on this for an '07+ Vantage?
Old Jan 29, 2018 | 02:34 PM
TR-Spider's Avatar
5 Year Member
TR-Spider is infamous around these parts
From what I know you would need to replace everything...the seat base with the motors and memory "brain", wire tree and switches.
So ok if you get a whole set from the junkyard, otherwise >2-3000 per seat.
Thomas
Old Jan 29, 2018 | 04:16 PM
blue2000s's Avatar
According to the parts list, it does appear that the seat "squab frame" and the seat wiring harness are specific to the memory seats.
Old Jan 29, 2018 | 04:37 PM
MRCW's Avatar
unless you have multiple drivers... you likely wouldn't use then as often as you think...
Old Feb 2, 2018 | 03:04 PM
brightoncorgi's Avatar
5 Year Member
brightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond reputebrightoncorgi has a reputation beyond repute
are the motors there?
I was fine with manual seats in my Evora. They were way quicker to adjust than power seats.
Old Feb 3, 2018 | 12:43 PM
deckman's Avatar
I have never used those. I wouldn't worry about it.
Old Feb 3, 2018 | 01:41 PM
bunob's Avatar
bunob is infamous around these parts
The wirings are different see the switch control :
3 connectors for the first one and only one for the memory seats.
Jul 29, 2019 11:13 AM
RallyBird
Oct 7, 2015 01:20 PM
Michael_s
Sep 11, 2015 08:03 PM
riozilla
Aug 21, 2015 11:34 PM
