Track Days in Your Aston
Old Mar 15, 2016 | 09:54 AM
  #61
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
Originally Posted by Sirdaft1
Do any of you track in the Midwest? Road America, Gingerman, Autobahn, Blackhawk, etc?
Yes, a few of us do.
Old Apr 11, 2016 | 01:12 PM
  #62
telum01's Avatar
Track season is getting started, and with that comes a word of caution. This was posted on YouTube yesterday:
Basically, the spokes on this guy's wheels had stress fractures that started on the inside of the wheel - not visible while the wheels where on the car. They eventually broke while he was on-track. The driver summed up the incident:
"Yup, the takeaway here is to inspect wheels regularly, even in the places that are hard to see. Forgestar actually got a hold of me and are offering a refund on the wheels and are going to buy me a replacement balljoint. They're going to take a look at the remaining wheels and do some analysis."
Old May 26, 2016 | 03:08 AM
  #63
bunob's Avatar
bunob is infamous around these parts
On your car you have brake cooling ducts : it is the RSC kit ?
It is needed to drill hole in the wheel arch ?
Old May 26, 2016 | 07:36 AM
  #64
telum01's Avatar
Yep, there are naca ducts cut into the front metal undertray and round ducts cut into the wheel liners. The ducts are riveted into place at each spot. I'll take some pictures tonight to show everything.
I'm not sure what all is included with the kit, mine might have been the first kit produced by RSC way back, and was done by the original owner.
Old May 26, 2016 | 08:57 AM
  #65
bunob's Avatar
Thanks for the pictures ;-)
Old Jun 3, 2016 | 09:51 PM
  #66
telum01's Avatar
So sorry for not posting this until now!
Here are the pics:
Old Jun 4, 2016 | 01:41 AM
  #67
bunob's Avatar
Thanks !
Old Dec 10, 2016 | 11:44 PM
  #68
era2076's Avatar
era2076 is infamous around these parts
Here are the pics:
How does this work? The ducting I have seen (and use) provides at least a partial shroud of the rotor with the air routed directly into the back side of the rotor.
The air pressure in front of the tire is high. I don't see how that is doing anything. Maybe there is more than shown?
x-chr
Old Dec 10, 2016 | 11:51 PM
  #69
Mathman85's Avatar
Mathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to all
That's not in front of the tire. It would, in fact, be aimed inside the rim of the wheel. The whole point is simply to increase airflow to the rotor itself. While having the ducting running all the way to the rotor would likely do a better job, that does not mean that increasing the air pressure inside the rim (which is what you're doing by funneling air into it) will help dissipate heat from the rotor.
Old Dec 11, 2016 | 08:05 AM
  #70
Old phart's Avatar
Old phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the roughOld phart is a jewel in the rough
AMOC has an event at Thunderhill in California in January. Anyone know the date, contact info for this year?
Old Dec 11, 2016 | 10:43 AM
  #71
era2076's Avatar
Originally Posted by Mathman85
That's not in front of the tire. It would, in fact, be aimed inside the rim of the wheel. ..............
Ah - I was thinking there would not be enough pressure to overcome the pressure between the tire and the fender liner and what ever was delivered would be swept away. Does Aston run this system in competition?
x-chr
Old Dec 11, 2016 | 11:19 AM
  #72
blue2000s's Avatar
blue2000s is a jewel in the roughblue2000s is a jewel in the roughblue2000s is a jewel in the rough
Forgestar F14 Failure at Buttonwillow - YouTube
Another thing to think about: Be wary of forged wheels that have been powder coated by someone other than the manufacturer. The strength of forged aluminum comes from the residual stresses left in the material during the forming process. Most powder coating anneals the metal, relaxing the molecular structure and weakening it, leading to potential wheel failures like this. There are low temperature processes that avoid unintentionally annealing, but it's not common.
Old Dec 11, 2016 | 03:15 PM
  #73
era2076's Avatar
Great post - I had a thin wall aluminum trans tunnel powder coated and I was very surprised how much the panels warped.
x-chr
Old Feb 6, 2017 | 04:28 PM
  #74
Callgre's Avatar
Callgre is infamous around these parts
Question re V8V handling characteristics
So, Aston go-fast gurus, a question: I just picked up an 06 V8V with 20K miles on it. It's running Pilot Sports with 33 PSI up front, and 36 in back. And I'm not having as much fun as I'd hoped. I am a prior owner of a number of fast cars -- ones that are easy to slide around in and be a general hooligan (BMW M3) and ones that could kick your a$$ pretty quickly if you weren't careful, again, when being a general hooligan (Ford Cobra replica with 440 HP small block). I've been able to tame them all, again, so I could be a general hooligan (are you seeing a theme?), but, honestly, the Aston kicks my butt routinely. When traction control is off and I'm trying for a nice, controlled drift, the car will settle in with very little angle OK, but there's a sharp edge between just that slight angle, and, "oops, here we go looping it again..." There doesn't seem to be a lot of neutral, playable space in between those two options. And, even when the corner is completed, the car is pretty abrupt when snapping back in line -- no graceful recovery to be found. Even with traction control on, in corners well over 100mph, it seems very nervous and not all that confidence inspiring. So, the question, is there something wrong with my particular used Aston, or are these just characteristics of the car? (Yes, I know I could go around corners faster without the back end out...) Thx in advance.
Old Feb 6, 2017 | 04:56 PM
  #75
Redpants's Avatar
Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !
Welcome to the forum!
My first thought is to drop the rear tires down a few PSI, especially if those are the pressures when cold.
Another thought is that the engine has a sluggish response to throttle inputs, so it may be that you're working your foot and steering inputs at one pace while the engine is lagging behind, and thus the power being put to the ground isn't what you're expecting. That might be what's messing you up in that neutral area where throttle (specifically, engine revs/power output) and steering inputs need to be in sync to keep control of the car.
