V8V Bonnet Latches
Old Oct 9, 2014 | 01:07 AM
Scotty4300's Avatar
Scotty4300 is infamous around these parts
V8V Bonnet Latches
I was aware that AM used some poor quality parts--but the bonnet latches on my 2008 Vantage look like the came from a Model-T Ford!
Mine were corroded so I took both the latch and lock plates off ,stripped them and refinished with black hammer finish paint.The rusty nut on the forward plate serves no purpose so I drilled it off.The plates are flat but the mating surface is not--so AM stuck a washer under one side as a spacer!
At least they now look a bit better.
ID:	404551   Click image for larger version
ID:	404552   Click image for larger version
Old Oct 9, 2014 | 02:22 AM
Vergis's Avatar
Vergis has a spectacular aura aboutVergis has a spectacular aura aboutVergis has a spectacular aura about
My bonnet flipped open at high speed. Caused a bit of damage. Luckily I wasn't driving it. Definately recommend making sure its in good order.
Old Oct 9, 2014 | 04:38 AM
karlfranz's Avatar
If I recall correctly "a bit of damage" is "a bit of understatement"
Old Oct 9, 2014 | 04:54 AM
Vergis's Avatar
Well it was bonnet obviously, windscreen and roof .
Also meant I needed a new wrap.
I have seen worse.
Old Oct 9, 2014 | 05:26 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
There is a service bulletin that the hood latch gets adjusted at every yearly inspection. I have seen a 2008 Vantage after the Latch gave out.
V565MAN
Oct 2, 2015 05:48 AM
larryg
Sep 28, 2015 11:16 PM
georgethomson
Sep 21, 2015 12:01 PM
vogz
Sep 19, 2015 01:02 PM
