Winter Projects
Old Nov 24, 2014 | 05:34 PM
  #31
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
Looks like there will be quite a few of us with the v12v s grills
Old Nov 25, 2014 | 09:31 AM
  #32
terminal_ac's Avatar
terminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to beholdterminal_ac is a splendid one to behold
Yup, installed last night!!
Interestingly, I had some installation issues with this in that the lower prongs did not meet up with the mounting holes. They lined up, but there was about a half inch gap. I needed longer bolts and spacer washers to get a "clean" mount. Other than that, I am happy with my grill.
Funny, but I'm still not sure whether I like this as opposed to my all black, 6 slat grill. I guess I'll hold on to my 6-slat grill just in case I want to go back to the original look.
Old Nov 25, 2014 | 10:33 AM
  #33
karlfranz's Avatar
Did you buy the grille from Aston or aftermarket? The installation parts should include 2 black 12mm spacer washers that are supposed to go under the prongs.
Old Nov 25, 2014 | 10:34 AM
  #34
karlfranz's Avatar
Also, when are we going to see pictures of your entire car?
Old Nov 25, 2014 | 12:19 PM
  #35
Eureka! I got mine from vcollection. Other than that, the part fits perfectly. So there's nothing wrong with it.
Do you know the part numbers for the spacers? I would love to maintain authenticity? (edit: The part No. is AD43-5435-AA; available from Astonbits or Scuderia)
I did upload pictures of the car, but prior to the mods going in. Will it be okay to provide pictures of the entire car once I complete all the mods over the winter, or would you appreciate pics as I go?
Last edited by terminal_ac; Nov 25, 2014 at 04:00 PM. Reason: Edit to add part numbers.
Old Nov 25, 2014 | 04:00 PM
  #36
Karlfranz, just curious but did you use the left and right brackets to mount your grill?
Old Nov 25, 2014 | 05:02 PM
  #37
mkzhang's Avatar
When the shop installed my grill (I was going to DIY but last min change of plans), the mechanic told me none of the spacers and screws for mounting weren't the right ones (length, fitment etc) and he had to use his own.
Old Nov 25, 2014 | 05:44 PM
  #38
karlfranz's Avatar
I ordered the genuine grille from my dealership and I asked them to make sure all the mounting hardware was included in my order. I used the spacers under the prongs with the longer bolts as well as the left and right brackets. I'm not sure why you would ask if I used the brackets. I can't imagine installing it without using them as there wouldn't be enough support.
The brackets and hardware were aluminum silver in color so I painted all of it in matte black so it doesn't show behind the black mesh as much. I also painted the Italian air horns I added in matte black for the same reason.
Old Nov 25, 2014 | 05:46 PM
  #39
karlfranz's Avatar
When the shop installed my grill (I was going to DIY but last min change of plans), the mechanic told me none of the spacers and screws for mounting were the right ones (length, fitment etc) and he had to use his own.
Perhaps there is a difference between the V-Collection grille and the OEM part.
Old Nov 25, 2014 | 05:52 PM
  #40
karlfranz's Avatar
This statement confuses me. You say you want to maintain authenticity so you buy an aftermarket grille and then want genuine mounting hardware?
Would be nice to see progress of your car as you go along. We haven't seen pics since you've done a few things to it.
Old Nov 25, 2014 | 06:07 PM
  #41
Yup, you've got me there. That is a bit of a contradiction, innit!
Okay, I'll see what I can do. However, there's not really much to see. So far, I've installed the glass switches for the glove box and the seat releases. I've also installed the alcantara gear shift, as well as a trunk mat.
Black window surrounds are being shipped, which I should receive tomorrow. I'll be installing those once I figure out how to get mine off the car.
I believe there is a difference between the vcollection grill and the Aston Martin grill because my grill is firmly in place, plus I cannot see a clear location to which the left and right supports would attach to my grill.
Old Nov 25, 2014 | 07:38 PM
  #42
karlfranz's Avatar
The brackets attach to the outer mounting holes used by the slat grill. There should be tabs on the 10 & 2 o'clock positions of the grille (assuming they copied the OEM one correctly). It takes one screw to attach each tab to the bracket and two screws to attach each bracket to the car.
Also, there are a ton of screws under the window weatherstripping that hold the window moulding to the car.
Old Nov 25, 2014 | 08:48 PM
  #43
There are no tabs at the 10 and 2 o'clock position on the vcollection grill. I guess this is a wrap, apart from order the 20 mm spacers.
Ok. This is good to know. I guess, I'll be removing the inner door panels to get this done. My thought is that I should download all the tech manuals for the car so as to remove any ambiguities with respect to assembly/disassembly.
Old Nov 30, 2014 | 09:24 AM
  #44
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
First Winter Task completed
A few weeks ago I found a left and a right clear tail light on two separate sources from E-Bay. Just installed them myself this weekend, it was interesting to take out the old red tail lights because it appeared to be two separate styles of mounting - perhaps there was a slight fender bender in the past!
Also I had to do a little inventive modifications because the was some oddity in the mounting posts coming from each light - all appeared to be Aston Martin parts.
In all I have about 2 1/2 hours into it and all the lights work fine - no error codes on my 09 Vantage.
Total cost under $400.
I'll do the seats (extra padding and diamond pattern) in February - the shop says it wants 4 weeks time (approx $2,500), and the new tires (20") when winter is over (thus I don't care about winter flat spotting).
When I take it in for inspection to extend the warranty another two years I'll also likely have the dealer replace the muffler with something a bit louder.
ID:	408821   Click image for larger version
Old Nov 30, 2014 | 09:13 PM
  #45
marioV8V's Avatar
marioV8V is infamous around these parts
My winter projects include:
-Complete piano black interior trim, waterfall, center console and arm rest
-Glass switches on waterfall, center console, glove box and seats
-Bright finish a/c vents, window and seat switches, silver speaker mesh
-Clear front and rear bumper lights
-Switching current clear tail lights with new units that are also clear but have a black border
