OEM Bluetooth Upgrade Installed: 2007 Vantage
Old Apr 4, 2018 | 03:21 AM
  #46
Paul Malcolm's Avatar
Paul Malcolm is infamous around these parts
How to use
I have just had this kit installed on my 2007 DB9. How do i select to play music via my phone? As in select the source as the car only has radio and CD selection on the dash..
Old Apr 4, 2018 | 07:23 AM
  #47
Irish07@VelocityAP's Avatar
If you did the dealer upgrade for a "pre to 2007 DB9", your car should of had the new head unit(ICM) and Bluetooth module. Looks like your heading back to the dealer, cause you should only need to select "Mode" then "BT" for Bluetooth streaming...
Old Apr 4, 2018 | 08:02 AM
  #48
Thanks for the reply, yes new module, ICM and everything is flashed. Steering wheel controls the Audio, Bluetooth phone calls work with phone directory.
Where is the Mode button for me to select Bluetooth?
Old Apr 6, 2018 | 09:06 AM
  #49
You have an older display so that should be the AM/FM and/or the CD button, think it might be the CD button and just toggle to BT. The newer display has the "Mode" button to toggle and doesn't have a CD button
Old Apr 6, 2018 | 02:02 PM
  #50
Yer its the older dash I have.
Thanks for the suggestions. Tried them but no luck. I think it needs to go back to aston
Old Apr 6, 2018 | 07:22 PM
  #51
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
With all due respect, F that. That is just to much money.
Old Aug 4, 2025 | 01:03 PM
  #52
def300s's Avatar
def300s is infamous around these partsdef300s is infamous around these parts
Hey guys. Just ran across this post. I recognize this is a pretty old post, but info is still relevant. I’m in the middle of working with an AM dealer on this upgrade. Part 7G43-37-10991 is advertised as available for pre-08MY. I’m trying to get it installed on my 2007 V8 Vantage. It came with Bluetooth for phone. Wanting to add this to stream music. Has anyone successfully added this recently?
COBB Tuning
Jan 1, 2025 09:02 AM
audipwr1
Sep 25, 2021 01:31 PM
Jul 29, 2019 11:13 AM
007 Vantage
Sep 4, 2015 06:55 PM
Prefurbia
Aug 28, 2015 06:28 AM
