OEM Bluetooth Upgrade Installed: 2007 Vantage
#46
How to use
I have just had this kit installed on my 2007 DB9. How do i select to play music via my phone? As in select the source as the car only has radio and CD selection on the dash..
#47
If you did the dealer upgrade for a "pre to 2007 DB9", your car should of had the new head unit(ICM) and Bluetooth module. Looks like your heading back to the dealer, cause you should only need to select "Mode" then "BT" for Bluetooth streaming...
#48
Thanks for the reply, yes new module, ICM and everything is flashed. Steering wheel controls the Audio, Bluetooth phone calls work with phone directory.
Where is the Mode button for me to select Bluetooth?
#49
You have an older display so that should be the AM/FM and/or the CD button, think it might be the CD button and just toggle to BT. The newer display has the "Mode" button to toggle and doesn't have a CD button
04-28-2022 12:38 AM
