Coolant and other issues
Old Mar 9, 2015 | 10:39 AM
ohTHATeric's Avatar
ohTHATeric is infamous around these parts
Starting to prep my 2011 V12 Vantage for coming out of winter hibernation (5 weeks in storage). Oil is good but I noticed the coolant is low. So, went to glove compartment to get the manual to see what type of coolant is recommended and the glove compartment won't open.
So . . .
1) Any tips/tricks for getting the glove compartment open?
2) Any recommendation on what coolant to top up with?
Thanks,
e
Old Mar 9, 2015 | 11:32 AM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
If dealer is close by, you can pick up 1 liter bottle coolant/antifreeze (#1R12322666AA). You will need to dilute it 50/50 with distilled water as it is a concentrated coolant.
I'd just top it off with distilled water, which would not dilute much and have any negative effect.
Old Mar 9, 2015 | 11:45 AM
ohTHATeric's Avatar
Thanks for the tips. Unfortunately, dealer is not close by (over 2.5 hours away). Is there a particular brand/type of coolant I can use for the V12? I'm hesitant to fill only with distilled water as it's low and don't want it to boil over.
Old Mar 9, 2015 | 12:13 PM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
is your car connected to a tender? with mine I find that when I open the door it temporarily activates all the electronics and thats when i can open the glove box, but when the door has been closed for a while and all the light goes off again, the glove box doesnt open
Old Mar 9, 2015 | 01:38 PM
cret's Avatar
Do you have leak? If not, a cup or 2 should remove the warning message and would be insignificant in a 4 gallon system.
Dan uses Prestone Dex-Cool on his DB9 https://www.6speedonline.com/forums/...procedure.html
I used a gallon of this when replacing the thermostat last year. I believe there's a 50/50 pre-mixed gallon available as well.
Old Mar 9, 2015 | 02:22 PM
ohTHATeric's Avatar
Got that and topped it up. Car fired right up--no warning lights and temperature is good.
However, I noticed that I have no center console power (stereo won't come on, no heat/ac) and, weirdly, no functioning turn signals. Might the battery have died over the winter despite being on a charger (and firing right up with no problem today)?
Oh, and still can't get the glove box open (thanks for the tip though mkzhang).
Old Mar 10, 2015 | 06:36 PM
Argus's Avatar
Argus is a jewel in the roughArgus is a jewel in the roughArgus is a jewel in the rough
Water is a better at drawing heat that a mix. When racing the mechanics always used water with just a pint of coolant to keep the system from rusting. But for you you want to keep the mix pending how cold it gets in your area.
Old Mar 11, 2015 | 08:19 AM
dan87951's Avatar
dan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to alldan87951 is a name known to all
Have you checked the fuses yet? Whenever I press the battery disconnect switch under the rear seat certain accessories in the car will no longer work (normal). Did you press the battery disconnect switch when winterizing the car?
Old Mar 11, 2015 | 04:06 PM
yankee04's Avatar
yankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond reputeyankee04 has a reputation beyond repute
They made 2x2 V12 Vantage? The battery disconnect switch is in the boot for most cars & inserting the key into ignition reverts it back to normal mode. Many of the center console fuses are under the passenger carpet & behind the aluminum panel. Get our your torx drivers.
adnanm3
Nov 22, 2023 02:43 AM
Rguy
Apr 12, 2020 11:11 PM
XLR82XS
Oct 5, 2015 07:02 AM
proTUNING Freaks
Sep 15, 2015 07:28 AM
faiz
Sep 2, 2015 08:43 PM
