New/used engine?
Old Apr 7, 2015 | 12:15 PM
theegolden1's Avatar
theegolden1 is infamous around these parts
New/used engine?
My 06 DB9 has the infamous "tick". Runs excellent, even when it ticks, but I want to go park it when the ticking starts. And the "fix" is leading up to engine removal. So I was wondering would it be more cost effective to just get a new/used engine? If used, what years are compatible with my 06? If I found another 06 engine, do I risk having that issue again?
I'm at a loss and I really don't want to get rid of the car. I really like it. But it's hard driving around sounding like an old ford (no disrespect to any ford owners, I own a Bronco also, which ironically doesn't tick with probably 200K miles).
Any suggestions?
Old Apr 7, 2015 | 02:42 PM
goto35's Avatar
goto35 is infamous around these partsgoto35 is infamous around these parts
How much is a new engine from UK? May not be a bad option if you are planning to keep car for a while.
Old Apr 7, 2015 | 02:47 PM
I do plan on keeping it for at least 5 more years. I found this online brand new for $12,000. I'm not sure if this is compatible or if I can find a better deal elsewhere.
http://allworldautomotive.com/auto_parts_for_sale_aston_martin_gas_engines_ots73 52.html"]http://allworldautomotive.com/auto_parts_for_sale_aston_martin_gas_engines_ots73 52.html
Old Apr 7, 2015 | 03:04 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Shipping that lump from the Netherlands won't be cheap.
Why not touch base with the Bamford Rose outpost in Arizona about a rebuild?
Old Apr 7, 2015 | 03:07 PM
Arizona? Have the car towed out there? I'm in Sacramento, CA.
Old Apr 7, 2015 | 03:08 PM
XJRS Owner's Avatar
That'll do just fine. If it is really new, jump on it. It's a bargain at that price.
Old Apr 7, 2015 | 04:15 PM
goto35's Avatar
$12k seems reasonable!
Old Apr 7, 2015 | 05:15 PM
karlfranz's Avatar
You might consider buying the new engine and then selling your existing engine to Bamford Rose so they can rebuild/upgrade it. That way, turn around time on V12 upgrades would be much quicker since they could have a freshly rebuilt motor to hot swap on standby. Of course, I'll charge Mike a commission per engine for coming up with the idea.
Old Apr 7, 2015 | 07:09 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
You might give Kevin Kay Restorations a call @ (530)241-8337 .
They are located in Redding, CA and could be a viable option for an engine rebuild that is closer to you.
Old Apr 7, 2015 | 09:56 PM
Thank you all for the suggestions. I will be exploring the advice given. But this really sucks for a high end car with only 40k miles..............
Old Apr 7, 2015 | 11:23 PM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
Prior the purchase of my current DB9 I was looking into buying one with engine damage myself. My initial plan was to buy the engine you're eying: I'd spoken with these guys in Holland (my native country as well) and they offered this brand-new engine at EUR 14k which is more then the USD 12K they market the engine in above link at. From memory the listed engine is no longer available, hence the higher price I got quoted.
I felt at the time that you can most probably spend less then EUR 14k to rebuild your current engine with forged pistons and such. Check out what Pavel did a while ago: https://www.6speedonline.com/forums/...e-rebuild.html
I ended-up buying a car without the issue but since you're having ownership already I'd consider getting it properly rebuild with high-performance parts instead.
Good luck!
PS: I can pass you the direct details of the chap in Holland if you want that. PM me for that.
Old Apr 8, 2015 | 09:20 AM
Good luck!
sdekoning, thank you very much for the info. Rebuilding sounds like a cheaper option. That'll probably be the route I take.
Old Apr 10, 2015 | 10:40 AM
DonL, I gave them a call. They only work on classics. But thanks for the help.
Old Apr 10, 2015 | 01:58 PM
XJRS Owner's Avatar
You might try giving this guy a call to see what a rebuild would cost.
Old Apr 10, 2015 | 06:40 PM
DonL's Avatar
It's unfortunate that they can't help you...were they able to give you any leads on a re-builder close to you?
