Time to get nimble
Old Oct 14, 2016 | 02:06 PM
  #271
Dalecannavan's Avatar
5 Year Member
Dalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to beholdDalecannavan is a splendid one to behold
Prefurba what colour is your car, it's nice?
Old Oct 14, 2016 | 03:24 PM
  #272
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
color
Aloro Green - with grey interior - that was a standard GT color... I specifically wanted that scheme.
Old Oct 15, 2016 | 10:45 AM
  #273
5 Year Member
Beautiful. That's the color I really wanted but couldn't find one. I then got impatient and bought a Tore Red, which I love, but secretly still want green.
Old Nov 7, 2016 | 11:47 AM
  #274
telum01's Avatar
I dropped THIRTY POUNDS for just 10 CENTS!!
Well, thirty pounds of pressure.
Good thing I have a spare in the garage...
Old Nov 7, 2016 | 11:54 AM
  #275
jfdeasy9608's Avatar
jfdeasy9608 is infamous around these parts
I was wondering where I lost that screw. Thanks for finding it for me. Seriously, sorry to hear about that. BTW, thanks for the tip on the shop for the wheel alignment. They did an excellent job.
Old Nov 7, 2016 | 12:04 PM
  #276
telum01's Avatar
Awesome! Good to hear
Old Nov 30, 2016 | 07:49 PM
  #277
Redpants's Avatar
Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !Redpants Is a GOD !
I've been wanting to replace the shifter surround in my car since forever. Finally did it! The carbon fiber one weighs only 1.6 oz. The original, much to my surprise, is milled aluminum - so it only weighs 6.0 oz. The top of the aluminum one is pretty dull on its own (like I've said, I think it looks much better when paired with a DBS shift ****), but the underside shows how much work went into making it.
The carbon fiber shifter surround is OEM from Aston Martin, and can be bought on my website: http://www.redpants.lol/shop/carbon-...shift-surround
Here's the comparison pic showing a 4.4 oz (over 1/4 lb) reduction in weight:
Old Jan 24, 2017 | 09:50 PM
  #278
Redpants's Avatar
Just ordered a clutch and lightweight flywheel from VelocityAP! That's supposed to shave 17 lbs from the car, so I'm down nearly 150 lbs in total. Shouldn't have a problem hitting 250 lbs at this rate And the lightweight flywheel should help with that sluggish throttle response, which is a huge bonus!
Old Jan 25, 2017 | 09:32 AM
  #279
flinder's Avatar
flinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to beholdflinder is a splendid one to behold
Expensive...but worth it.
Telum/Redpants. You are going to love the changes this modification brings to your car.
Old Jan 25, 2017 | 10:02 AM
  #280
handyman2009's Avatar
Veteran: Canadian Forces
Are you doing your own install ??
Old Jan 25, 2017 | 10:50 AM
  #281
Redpants's Avatar
Not solo, but yes
Old Jan 25, 2017 | 03:47 PM
  #282
Redpants's Avatar
On its way!
Old Jan 25, 2017 | 03:56 PM
  #283
skywagon's Avatar
skywagon is a jewel in the roughskywagon is a jewel in the roughskywagon is a jewel in the rough
I am planning on swapping to this clutch either late this year or early next year. The only tool I might need to purchase is one to compress the new clutch assembly for install. Have you decided on one to use for that? I will be installing this one myself.
Old Jan 25, 2017 | 04:54 PM
  #284
Redpants's Avatar
I might end up ordering one (they're expensive, though), but it's possible to install without the compression tool. It's just very tedious and you have to be extremely careful.
Old Jan 25, 2017 | 08:09 PM
  #285
DetomasoGTS74's Avatar
Rich-per our PM you will love it. I would call it the single biggest improvement out of 8 years of mods to my V8V. I would also offer up that you should do the headers as well at the same time. I did it with a friend and we were able to do clutch, flywheel and headers in roughly 10hrs.
We did a dyno on my 4.3L post install in 100 degree heat and the car put down 375. I am considering adding the 2 piece rotors and removing the air boxes as my last NA changes to the car and will dyno in cooler weather. Hoping to hit 400 at the wheels naturally aspirated. That and close to 150lbs taken off has transformed this car entirely!!!!
