Wheel Removal
Old Jun 30, 2015 | 08:36 PM
BeenThere's Avatar
BeenThere is infamous around these parts
Wheel Removal
I've search this forum and more, read the manual, etc. and can't find an answer to this simple question: How do I remove the front wheel? I don't have a flat, I just need to take the wheel off. I'm can't figure out how to do this basic task.
Out of nowhere, I start getting a horrid metal-on-metal scraping sound out of the right front wheel. I just want to examine what it might be. Recently, my son had a similar issue with his BMW 330 CI. Turns out he had a small pebble stuck between the rotor and caliper. Took the wheel off to examine and it popped out - problem solved. Lot's of new construction around me and thinking it might be the same thing. Or - something else - I just want to examine.
So, is there anything as silly as just being able to jack up my car, take off the wheel and look around - without putting it on a lift?
2009 V8V Coupe
Old Jun 30, 2015 | 09:44 PM
DonL's Avatar
Active Streak: 120 Days
DonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant futureDonL has a brilliant future
I suspect this information should help you out...there's lots of information on the forum regarding jacking pads as well.
File Type: pdf
Old Jul 1, 2015 | 12:14 AM
wysoseereeus's Avatar
wysoseereeus is just really nicewysoseereeus is just really nicewysoseereeus is just really nicewysoseereeus is just really nice
Take a look at this thread: https://www.6speedonline.com/forums/...ngine-bay.html
We touch on the subject of jacking up the car which I had to do for the first time. Not too bad although I did buy special jackstands to do it.
Old Jul 1, 2015 | 07:00 AM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
If it's just a rock in the brakes (happens to me once in awhile) it usually falls out on its own. Backing up & braking sometimes helps to dislodge it.
Old Jul 1, 2015 | 08:09 AM
XJRS Owner's Avatar
Originally Posted by yvr
If it's just a wheel in the brakes (happens to me once in awhile) it usually falls out on its own. Backing up & braking sometimes helps to dislodge it.
What?
Old Jul 1, 2015 | 08:57 AM
yvr's Avatar
yvr
Originally Posted by XJRS Owner
What?
Fixed it!
Old Jul 1, 2015 | 03:53 PM
BeenThere's Avatar
Thanks All for the info.
I've had the car for a year and haven't had any issues other than a bad rear turn signal light. I made the mistake of pointing that out to my wife and within 24 hours this happens.
I'll dig into this and see what I may have going on in there.
Jul 29, 2019 11:13 AM
DonBond
Apr 16, 2016 07:55 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
Sep 1, 2015 03:16 PM
acf
Aug 24, 2015 10:34 AM
