V8 vantage knock/tapping sound
Old Jul 18, 2015 | 05:51 PM
MRY's Avatar
MRY
MRY is infamous around these parts
Originally Posted by Hocdoc527
If in fact its engine bearing would knocking sound be there on cold start?
Yes, it would be there all the time if a main or rod bearing was bad.
Old Jul 20, 2015 | 06:10 PM
phy6's Avatar
phy6 is infamous around these parts
Could be a valve lash issue?
How is your oil level/oil consumption, and are you seeing a lot of oil in the intake?
After learning that the V8/V12s are based on Ford Duratec parts, I'm much more at ease about engine rebuilds. It seems the powdered metal rods are the cheapest part in there, and the lubrication on the stock rod bearings leaves something to be desired. If you search youtube there is a video on a DB9 engine rebuild.
I think they quoted the rebuild cost about 15k, but now the rotating assembly is bulletproof.
You might also consult Pavel's racing engines here:
http://pretuning.com/2013/06/2009-as...ngine-rebuild/
He sells rod/pistons/bearing kits on ebay as well.
Old Jul 22, 2015 | 10:10 PM
Hocdoc527's Avatar
Hocdoc527 is infamous around these parts
Coil replaced
Just replaced coil for 113 bucks. Reset codes... Still get misfire in cylinder 3... Plus intermittent knock/tap sound. Yes will tow to dealer but any other suggestions are appreciated. 26,900 miles on car. Makes no sense to me...
Marcos AMV8
Dec 18, 2015 06:03 AM
midwestamv8
Audi
Sep 9, 2015 11:53 AM
mindscape9
Sep 8, 2015 12:02 PM
karlfranz
Aug 19, 2015 09:05 PM
