Thought you'd find this funny...
Old Aug 13, 2015 | 02:04 PM
spikemd's Avatar
spikemd is just really nicespikemd is just really nicespikemd is just really nicespikemd is just really nice
This is the key I bought. Should be arriving tonight. From the post, looks like it is not branded and has the key in order to attach the key ring.
http://www.ebay.com/itm/311321663644
Will post more when I gut it.
Old Aug 13, 2015 | 02:17 PM
kensilver's Avatar
kensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud ofkensilver has much to be proud of
That looks perfect. Please share the details when you get it!
Old Aug 13, 2015 | 02:32 PM
kensilver's Avatar
What the heck... it looks logo-free so I just bought two. Now looking for an AM emblem to cement on the face.
Old Aug 15, 2015 | 03:11 AM
Kevwood's Avatar
Kevwood is a jewel in the roughKevwood is a jewel in the roughKevwood is a jewel in the rough
I bought the same design, works very well after a little internal dremeling.
Old Aug 15, 2015 | 04:40 AM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
Originally Posted by kensilver
Sadly no longer available. Anyone have any update on that key? I don't really want to re-cover a Jaguar key with leather - it never comes out the same as a factory-produced product.
I bought the FOB's here: http://www.ebay.com.sg/usr/autoniz (make sure the seller confirms it's not having the Jaguar Logo)
I bought the Aston Martin logo pin's here: http://www.ebay.com.sg/usr/pinlady-1
Old Aug 15, 2015 | 04:41 AM
kensilver's Avatar
How so? I thought the innards from the original key fitted straight in. Can you give more detail/pics?
Old Aug 15, 2015 | 05:05 AM
Kevwood's Avatar
They do but they don't fit flush.
The inner 'plate' of the Jag fob is curved and the AM circuit board sits against it but leaves a significant gap which means you have to really push the buttons hard to make contact. I filed a significant amount of the internal plate off to allow the circuit board to sit closer & fit better then added a spacer - works like a charm now. The trial and error only took about an hour, now that I know what needs to be filed & where it's a 5 minute job. I'm a bit of a perfectionist so to some it may be overboard but to me it's 'right'. I also added the AM log (pin) on the back side.
When I get back to Dubai I will take the fob apart again and post some pics for you.
Old Aug 15, 2015 | 05:38 PM
kensilver's Avatar
...When I get back to Dubai I will take the fob apart again and post some pics for you.
Thanks, that would be useful.
Old Aug 25, 2015 | 01:02 PM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
I also find myself pushing hard on the buttons to make contact. Pics on the spacer please?
Old Aug 25, 2015 | 11:24 PM
spikemd's Avatar
I opened my FOB up and started modifying the jag one. I had to snap off a middle piece of plastic and noticed the internals do sit lower. But when I was trying to fit everything together, I realized the seller sent me two of the same sided chrome outside pieces and it wouldn't close properly. In addition, he did not send me the spare key part. I contacted the seller and he sent another FOB which should work. Will post when I get it fitted.
I'm in the middle of changing the head gasket on the my Range Rover which is causing some headaches...
Old Aug 25, 2015 | 11:26 PM
spikemd's Avatar
Pics please. What type of material did you use for the spacer?
Old Aug 30, 2015 | 03:55 AM
kensilver's Avatar
...In addition, he did not send me the spare key part. I contacted the seller and he sent another FOB which should work...
My remotes arrived today and also didn't have the key blades enclosed either.
Old Sep 19, 2015 | 05:34 AM
kensilver's Avatar
Gets worse. The company say they changed their order to show the blades weren't included (but the ebay ad still shows them as part of the order), and will not send the missing items to me because their system won't allow international order replacements.
Never heard of anything quite so silly as this. I asked for a refund of the missing items which they had originally offered, and will order the blades from somewhere else.
What a waste of my valuable time. The end result better be worth it
Old Oct 26, 2015 | 10:04 AM
spikemd's Avatar
Finally done.
Kensilver, sorry to hear about your fiasco. When I contacted the seller, they sent me a new fob with the correct sides and the uncut spare key. Finally changed it over this weekend. With the correct sides, the internals dropped into easily. A little harder to press the buttons but much better looking.
Only need to cut off the pin inside the new fob for the electronics to drop in. Keep the spring for the key release from popping up and close the backing.
danyoP4S
Sep 30, 2021 05:06 AM
Paintballzen
Oct 10, 2020 12:22 PM
cm09578
Sep 22, 2015 06:07 AM
speedyizzy
Sep 11, 2015 06:31 PM
Casino_Royale
Sep 2, 2015 12:24 PM
