Sill trim plaque removal
Old Oct 18, 2015 | 09:47 AM
larryg's Avatar
larryg is infamous around these parts
I purchased a new brushed stainless "Made in England" plaque to replace my scratched one on the sill trim. It is secured by two very small Philips head screws.
I can't seem to loosen the screws. Any advice?
Old Oct 18, 2015 | 10:50 AM
Vantagelvr's Avatar
Vantagelvr is infamous around these partsVantagelvr is infamous around these parts
Impact screwdriver , don't go crazy with it though .
Old Oct 18, 2015 | 04:17 PM
XJRS Owner's Avatar
Probably Pozidriv, not Phillips, that's why you are having trouble? Can't begin to imagine using an impact driver for those small screws!
Old Oct 18, 2015 | 04:22 PM
larryg's Avatar
What is pozidrive?
Old Oct 18, 2015 | 05:17 PM
Vantagelvr's Avatar
Im not suggesting he use an impact driver and a 6lb sledge to pound on it . Impact screwdrivers can be used just with a pound of your palm or just bearing down with you body weight sharply .
Pozidrive is a UK style of Phillips type screw with a different angle to the groves that make up the cross shape . The sill plate screws are just regular Phillips head .
Old Oct 18, 2015 | 05:52 PM
larryg's Avatar
Nothing is easy on an Aston
Old Oct 18, 2015 | 07:21 PM
XJRS Owner's Avatar
What is pozidrive?
Most screws are PZ on your Aston. Using a Phillips bit will eventually ruin the head (you'll wonder why your Phillips drivers keep camming out when you try to remove a stubborn screw). Check on line to learn the visual differences between the two styles.
Old Oct 18, 2015 | 07:56 PM
BeenThere's Avatar
BeenThere is infamous around these parts
Well, I feel dumb, but this now explains a lot about my forays and foibles regarding repairs to the AM.
Old Nov 7, 2015 | 11:16 AM
larryg's Avatar
Purchased a set of Pozidriv screwdrivers at Lowes.
Worked perfectly.
Changing the plaque took less than 1 minute.
gjpearce
Oct 17, 2015 03:19 PM
carlosC4S
Cayenne 955/957
Oct 16, 2015 09:47 AM
W.E. Cameron
Audi Vendor Classifieds
Oct 14, 2015 09:14 AM
mike@mautolite
Sep 30, 2015 05:32 PM
mike@mautolite
Cayenne 958 Vendor Classifieds
Sep 30, 2015 05:31 PM
