Tire width
Old Dec 9, 2015 | 08:42 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
Tire width
What is the widest tire you can fit inside the wheel well on the stock 19" wheels?
Old Dec 14, 2015 | 03:56 PM
Montana107's Avatar
Montana107 is infamous around these parts
I believe the below questions will help us answer:
What is the width of your 19 inch rears? Example is your car an early Vanatge V8, V8VS or a V12S or a different model? They have different sizes - Also do you plan to run spacers?
Old Dec 15, 2015 | 12:00 PM
randyb's Avatar
Sorry, would like to widest tire that will fit on a 07 DB9 with stock rims.
Old Dec 15, 2015 | 02:38 PM
Montana107's Avatar
Sorry - I am a Vantage guy so I have no knowledge for your model
good luck!
Old Dec 15, 2015 | 03:30 PM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
It depends on the rim width. Your OE stock rims should be 8.5J front (235/40/19) and 9.5J rear (275/35/19). 8.5J maxed out at 255 but most of us do 245. 9.5J maxed out at 285.
Old Dec 15, 2015 | 03:32 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
DB9 standard wheel sizes are 19x8.5F, 19x9.5R. I'm running 245/40F and 285/35R (slightly taller & wider than standard 235/40F and 275/35R).
I've read about owners using 255F & 295R, and I'm guessing that's about max on standard wheels.
Old Dec 15, 2015 | 10:34 PM
anton28's Avatar
anton28 has a spectacular aura aboutanton28 has a spectacular aura about
I'm running a 325 21" I could have ran a 375 but it's a discontinued tire. You can fit a lot of rubber under the rear fenders, it all just comes down to your wheel size/width.
Old Dec 16, 2015 | 09:38 AM
XJRS Owner's Avatar
But a DBS ain't a DB9, so not applicable.
2001f4s
Dec 10, 2015 06:38 PM
WheelB
Nov 12, 2015 02:06 PM
WheelB
BMW //M
Nov 11, 2015 12:32 PM
WheelB
Other British Cars
Nov 10, 2015 11:57 AM
