Throttle accentuation issue.
Old Dec 29, 2015 | 11:02 AM
oo7's Avatar
oo7
oo7 is just really niceoo7 is just really niceoo7 is just really niceoo7 is just really nice
Throttle actuater issue.
Registered A "Red Triangle" fault for Throttle Actuater fault. Cleared it returned once in the last week, it is accompanied by a sluggish throttle response. Anyone else experience? Will post resolution for future reference.
Old Dec 30, 2015 | 08:46 AM
telum01's Avatar
Did the throttle body go bad?
Old Dec 31, 2015 | 07:37 AM
oo7's Avatar
oo7
Not sure of anything yet. Going to make a few more calls today and take my indie garage that does all my work. The code is P2106 -powertrain Throttle Actuator Control system- Forced Limited Power. First non typical issue for me, can not really complain, have 84k miles
Old Dec 31, 2015 | 03:28 PM
oo7's Avatar
oo7
Have been told butterfly gets "gunked up" and will cause an issue.
Old Jan 1, 2016 | 11:42 AM
Irish07@VelocityAP's Avatar
That fault usually stores when another fault is dangerous to the engine..so the throttle is forced to shut down..
You can have a transmission fault with ASM equipped and also store this fault, which dtc will not pop up on a generic scan..
When ever I've had JUST a throttle go bad..this code was accompanied by a throttle correlation fault
Technical Director
Christopher Edgett
214 Maple Ave.
Oliver, B.C
Canada V0H 1T9
Office: (1)250-485-5126
Email: Tuning@VelocityAP.com
www.velocityap.com
Old Jan 1, 2016 | 04:05 PM
oo7's Avatar
oo7
Thanks for the input irish07, most appreciated. Mine is a manual and the triangle is accompanied by hesitation at idle coasting no throttle, but no diminished power otherwise. I am going to thoroughly clean the butterfly tomorrow morning and drive. Fault only occurred in the cold, not after hot. I read that my driving style and bad gas may be causing an issue with the butterfly sticking. Any further input would be most appreciated and I will post updates/solution.
Old Jan 1, 2016 | 05:16 PM
It doesn't heart to have it cleaned..I take them off and clean them with a old tooth brush and throttle body cleaner spray NOT something is also good got care cleaning, not the same.
Then after reinstalling, wait a few seconds with the ignition on and you'll hear the throttle body clicking.. That's the initial calibration done on every start for the throttle body.
As for driving style, I don't see this being an issue unless you drive around like a 120 year old man who doesn't push the throttle past 20%.. Driving hard or moderately aggressive, doesn't cause idle or stalling and gunk things up "as much".
Old Jan 1, 2016 | 07:39 PM
spf1410's Avatar
spf1410 has a spectacular aura aboutspf1410 has a spectacular aura about
Uhhh, I guess I'd better get a heavier right foot.
Old Jan 2, 2016 | 12:46 PM
oo7's Avatar
oo7
Ok, I do drive like an old man... I had planned on taking apart and cleaning manually, however my ignorance of how to open the clip prevented me as I was afraid I would break it, and had no replacement. I purchased an expensive can of highly recommended cleaner to ad to the fuel made by the carb cleaner company, added it to 3/4 tank of gas and drove like a youngster, of course only after car reached temp. Actually saw that funny light that comes on when revs approach limit, lord knows how much gas I burned through in that endeavor. Seems to have cleared up the problem. I had filled up a few times at convenience stores, not by choice, and hoping the cheap gas may be the culprit. Thanks again irish07 for the input and advice. I believe in the future I may drive in a more spirited fashion.
Old Jan 2, 2016 | 03:25 PM
telum01's Avatar
"My car is acting up."
"Beat it like a redheaded stepchild."
"Hey it worked. It's behaving now."
(no offense to redheads, stepchildren, or combinations thereof)
Old Jan 3, 2016 | 05:08 PM
oo7's Avatar
oo7
Problem has abated. I will have it cleaned more thoroughly next servicing. Side note, as per irish07 remarks I wait to hear the reset clicks of the butterfly before engaging the starter. I am becoming more accustomed to seeing over 2k revs on the tach, though had to talk my way out of a ticket tonite, TG the young trooper liked the car...
