Best Replacement Battery?
Old Jan 2, 2016 | 11:06 AM
Ducati348's Avatar
Ducati348 is infamous around these parts
I see that the stock battery for a 2009 Vantage is a Varta 2R83-10655 -AA. When I look that up, it crosses over to several different suppliers. There is a Bosch replacement, an EXIDE replacement and a few others. I would like one that fits exactly (with appropriate vent) and has a few more CCA.
Does anyone got a good recommendation? If possible, please provide any details.
Old Jan 2, 2016 | 08:42 PM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
You could go the lithium ion route. Way more power and a small fraction of the weight... The only downside is the cost.
Old Jan 2, 2016 | 08:55 PM
dicktahoe's Avatar
dicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of lightdicktahoe is a glorious beacon of light
I went with the Bosch and it fits perfectly.
Old Jan 3, 2016 | 05:16 AM
chiter1213's Avatar
chiter1213 is infamous around these parts
Went with the Duracell Ultra Platinum Part#: SLI49AGM since the Bosch was not in stock at the time. Perfect fitment and works great
Old Jan 24, 2016 | 03:01 PM
Organeer's Avatar
Organeer is infamous around these parts
Is there not a possibility of fire using Lithium Iron batteries?
It is important to use a battery that has been maintained correctly during storage. Car batteries self discharge during storage and if not maintained/trickle charged they will have a shortened life span and reduced capacity.
Old Jan 25, 2016 | 10:06 AM
WG_moots's Avatar
WG_moots has a spectacular aura aboutWG_moots has a spectacular aura aboutWG_moots has a spectacular aura about
I replaced the battery in my V12V a few weeks ago. Bosch has on that is the same size and specs as the original ... and yes, the vent is also in the same spot as the original Varta. My local Pep-Boys had one in stock. I replaced mine the same day I took out the original. Search for battery replacement and you find an informative thread with a "how-to" video on the removal/install.
Old Jan 25, 2016 | 11:36 AM
DonBond's Avatar
DonBond is just really niceDonBond is just really niceDonBond is just really niceDonBond is just really nice
Odessey
Old Jan 27, 2016 | 11:29 PM
dsvantage's Avatar
dsvantage is infamous around these parts
Does anyone know the weight of the Duracell, Bosch, and OEM battery?
Old Jan 28, 2016 | 07:27 AM
telum01's Avatar
OEM Varta battery is 53.5 lbs. I'm dropping in a Braille B3121 and it's cutting 30 lbs from that
Old Jan 28, 2016 | 07:53 AM
cret's Avatar
cret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond reputecret has a reputation beyond repute
Not sure about the Duracell AGM, but the Ultral Gold is 51 lbs
Old Jan 28, 2016 | 09:04 AM
Organeer's Avatar
How much more does a battery weigh when fully charged?
Old Jan 28, 2016 | 12:28 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
The same, well not enough that a scale would notice, i.e. a fraction of an ounce. Weight only changes if you lose the water in the battery.
Old Jan 29, 2016 | 05:33 PM
farrbar's Avatar
farrbar is infamous around these parts
My dealers uses Interstate. I bought direct and saved $.
Old Sep 22, 2016 | 06:48 AM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
Bumping this:
How do you find battery that fits our cars? I did a general search on amazon, but should i trust amazon to tell me the battery fits a vantage?
Old Sep 22, 2016 | 08:47 AM
cret's Avatar
Group Size 49 (H8)
Originally Posted by mkzhang
Bumping this:
