H&R springs or coilovers?
Old 02-03-2016, 03:52 AM
mantonkroh's Avatar
mantonkroh is on a distinguished road
Hello friends,
I have read through many threads but looks like I can't get a clear answer. I'm hoping this will resolve my issue, and possibly for others.
Background: I have a 2013 AMV8V with sports pack (Bilstein). I'm looking to lower my car only 3/4-1.00" and mounting 20" HRE P101s. I'm hearing that I should just go with the .75" lowering springs from H&R rather than coilovers because the drop isn't significant. If I were to attempt a more aggressive drop, I was recommended coilovers.
Question: For those who went with springs instead of coilovers, what was your experience? Was the ride comfort compromised? Would you recommend springs instead of coilovers for a maximum 1" drop? Any advice would be greatly appreciated!
Thanks in advance!
Old 02-03-2016, 05:33 AM
MadeInPorshe's Avatar
MadeInPorshe will become famous soon enoughMadeInPorshe will become famous soon enough
I've also got sport pack on my V8V and will be installing the H&R springs next week sometime so I'll have some feed back with the blistein dampers paired with the h&r's.
I've heard a lot of mixed reviews on this and decided to try it out for my self. Although, coilovers would be the best option
Old 02-03-2016, 08:00 AM
telum01's Avatar
General consensus is that you do not want to put H&R springs on the Sport Pack struts because they're mismatched and will cause a "pogo" effect. I have them on my standard (non-Sport Pack) struts and they're great but very low.
KW and Nitron both make coilovers. I've heard a ton of great stuff about Nitron's. Haven't heard much at all about KW's but their products tend to have a great reputation. I was going to go with Nitron but might end up doing KW struts with custom linear springs as a project.
Old 02-03-2016, 03:29 PM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
Originally Posted by mantonkroh
Hello friends,
Thanks in advance!
We developed a lowering spring for exactly the reasons you're describing - the desire to lower close to an inch, but not slam the car, and to do so without compromising ride quality. Many people complained to us about the H&R 'Pogo' effect. Our tapered springs lower the car 7/8" and have been installed by a number of 6speeders. All have reported that the ride quality was either no worse, or some felt it was improved, compared to the OEM springs.
https://www.6speedonline.com/forums/...ct-launch.html
We have a container arriving from our manufacturer in Australia in about 5 weeks.
Coilovers is a whole other level of cost. We do offer the Nitron setup, which is very nice on the street and ride height adjustable:
http://www.velocityap.com/Aston-Mart...v8coilover.htm
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old 02-03-2016, 06:42 PM
mantonkroh's Avatar
Awesome! Would love to get your feedback and also photos!
Old 02-03-2016, 06:43 PM
mantonkroh's Avatar
Thanks Stuart! I will do further research on your springs.
Old 02-03-2016, 06:45 PM
mantonkroh's Avatar
Thanks Telum01. I've heard the same and that's a big concern of mine. But some say the ride quality is just fine. Using other peoples' personal preference is a challenging way to make a decision. Lol. Thanks for your input.
Old 02-03-2016, 07:27 PM
Montana107's Avatar
Montana107 is on a distinguished road
I have done both on my V8VS - H&R do not work well with the sport pack - mismatch to the dampers - I have a set for sale for a non sport pack Vanatge if anyone is interested.
I went with the Nitrons and I am very pleased with the ride but still need to dial in a few items before a full report -
If you want springs only I would recommend Stuart's solution -
Cheers!
Old 02-03-2016, 07:47 PM
mantonkroh's Avatar
Thank you Montana107. I will do research on Stuart's springs. Just curious, why did you go with coilovers instead of the springs that Stuart is discussing?
Old 02-03-2016, 08:09 PM
Montana107's Avatar
I wanted a more track focused solution with linear rate springs to my specs and ride height / corner weight adjustablility
Old 02-03-2016, 08:54 PM
Maple Valley 996T's Avatar
Maple Valley 996T is on a distinguished road
My '07 V8V came with H&R mounted and stock 19" wheels, no rubbing and great performance on spirited mountain road drive, lots of compression/rebound, very predictable!
Old 02-03-2016, 09:16 PM
mantonkroh's Avatar
Gotcha! Makes sense. Thank you.
Old 02-03-2016, 09:17 PM
mantonkroh's Avatar
Thanks Maple Valley for the insight.
Old 02-03-2016, 09:43 PM
impulsiv's Avatar
impulsiv is a jewel in the roughimpulsiv is a jewel in the roughimpulsiv is a jewel in the rough
I just got H&R on my 09 Vantage/sport. I installed them, droped the car from the jackstands, raised it again and removed them springs. If you want them, they're for sale. Rear camber was like -5 degrees, there's no way to achieve the spec at -1.75 degree doing the alignment. Way too low.
Velocity springs on their way.
Old 02-03-2016, 11:01 PM
Here's the skinny - the front springs are basically the same from sportpack to non-sportpack. Just a few mm static length with similar spring rates, basically means nothing on loaded height. The rears are TOTALLY different. H&R on a Sportpack car will drop the **** end of the car about 1.5" further than the front.
Which is why we bench tested sportpack springs to come up with a correct solution for the rears, which doesn't drop the car 2" from standard. This is Sportpack on H&R. It's really, really low.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Quick Reply: H&R springs or coilovers?
