Help - Center Console 2009+
Old Mar 29, 2016 | 11:20 AM
handyman2009's Avatar
Veteran: Canadian Forces
I am trying to remove the center console so that I have access to the Shifter (replacing it with a DBS version) and I removed the 2 screws under the cup holder rubber and the metal bar behind the seat (which had 1 screw holding the center console) but it is still holding by something and I don't want to break anything. I tried pulling and pushing forward and backward like in the DB9 video online but that didn't work. Can someone help, thanks
Old Mar 29, 2016 | 01:24 PM
EZ Cookin's Avatar
EZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud ofEZ Cookin has much to be proud of
If you have a DB9 it is like the video. If you have a Vantage there are a few more steps. Clarify what vehicle you have.
Old Mar 29, 2016 | 02:34 PM
Sorry I have a 2009 Vantage Coupe 6sp Manual
Old Mar 29, 2016 | 06:47 PM
I figured it out, I think I will do a little video (DIY) when I have a minute... It wasn't as obvious as the DB9 that's for sure.
Old Mar 29, 2016 | 10:32 PM
EZ Cookin's Avatar
Sorry I have been away from a computer all day. The Vantage is a little more involved. Especially the roadster version. I did this to change out all my plastic buttons to the updated glass buttons a while ago. If you get stuck let me know.
Old Mar 30, 2016 | 04:26 AM
Thanks for looking out for me, I was able to it just took a little longer to figure it out... As they say Slow and Steady wins the race :-)
Old Mar 30, 2016 | 08:34 AM
will007's Avatar
will007 is infamous around these parts
Adding to this topic -- has anyone ever installed a 08+ center console into a 06-07 Vantage Coupe? I know you would not get the electronics (or would you?), but the forward cup holders and higher armrest are a plus.
Old Mar 30, 2016 | 10:55 AM
I believe that I read that it is possible but can't remember where I saw it, if I come across the post I will let you know.
Old Mar 30, 2016 | 11:31 AM
skywagon's Avatar
skywagon is a jewel in the roughskywagon is a jewel in the roughskywagon is a jewel in the rough
Here is one post where someone made that change:
https://www.6speedonline.com/forums/...-retrofit.html
I am considering it as well but my concern is it being in the way of shifting. My Vantage has a manual transmission.
Old Mar 30, 2016 | 12:16 PM
XJRS Owner's Avatar
It is useless with a manual since anything in there interferes with shifting. OK for SSM or auto box.
Old Mar 30, 2016 | 12:31 PM
Not sure what you are talking about, if it was useless AM would have stop making that console a long time ago but yet they are still using it. They do have a little insert that goes into the driver side cup holder for people that complain. I like that console a lot more than the earlier model that dates the interior of the car, same goes with the early 2006 model and the seats.
Old Mar 30, 2016 | 01:25 PM
XJRS Owner's Avatar
You can't shift the car if there's something (like a coffee cup) in the holder. If you have SSM or auto, however, it can be used. But a far better choice for auto/SSM is the cubby aft of the radio console.
Old Mar 30, 2016 | 01:54 PM
Ron Avery's Avatar
Ron Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to behold
I've wondered about this as well with my 2007 vantage.
Ron
Old Mar 30, 2016 | 02:36 PM
I was able to shift just fine with a coffee cup in the passenger holder as I have that little pad in the driver side. Problem solved.
Old Mar 30, 2016 | 08:39 PM
will007's Avatar
Thanks -- exactly what I was looking for.
