New Method to stop brake squealing
Old May 11, 2016 | 05:57 PM
Joe The Angel's Avatar
Joe The Angel is infamous around these parts
Just try BG 60 ...its so cheap around $20 and you will get a result that you will be amazed by. I was.
Old May 15, 2016 | 11:57 AM
007 Vantage's Avatar
007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of007 Vantage has much to be proud of
BG Stop squeal would have cost you $20 and it would have done a better job without removing any of the pad material.
Next time just go with BG stop squeal
Old May 17, 2016 | 04:25 AM
BMW-North's Avatar
BMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant futureBMW-North has a brilliant future
RudyP can I ask where you ordered them? I need to get this embarrassing squeal fixed. I sound like a city bus pulling up to a stop light.
SOLUTION
Edit: In case anyone reads this thread and has the squealing brakes. The original owner of my Aston Martin Vantage V8 paid Aston MArtin in Vancouver $1100 to fix this and it did not work. According to the work order they removed and cleaned the contact areas and reseated the pads with new shims.
I bought the car from the original owner who was embarrassed to drive this car in city traffic due to the squealing and gave up after forking out the money for nothing.After a week of driving with the squeal I too started to get embarrassed and found this thread.
I fixed it using CRC Disc Brake Quiet compound. It is like a high temp RTV that you apply directly on the pad backing. It turns rubber like and absorbs any vibrations that resonate into squeal. I put a thin coating underneath the shim and on top of the shim. I put it on all 12 pads (inc. parking brake pads) let it sit for an hour then re-assembled the brakes. Been 2 months now and no squealing. Also no reduction in braking ability The CRC Disc Brake Quiet was $7.95 for the bottle.
BTW - I am affiliated with no one - just a petrol head
Mr.Boon
Apr 6, 2021 03:50 PM
997 Turbo
Apr 11, 2016 11:03 AM
magoochi
Apr 10, 2016 01:20 PM
Jeff_335i
Apr 8, 2016 09:22 PM
