2007 Vantage V8 Audio fuse
Old Apr 23, 2016 | 09:06 PM
Arm818's Avatar
Arm818 is infamous around these parts
Ok so i took my car to have Aux installed last week and after i dropped off the car the guy called me back saying that there was something wrong wrong with my radio that it wasnt working after checking the fuses he found out that the fuse was burnned and that the Aux device he was install wasnt the right one so i went back to pick up the car without anything installed on it till he gets the new part. But ever since i got the car back my fuse keeps braking after i turn the radio on and when i called the guy he said he didnt touch anything beside discconect and reconnecting my antenna, i dont want to put higher amp fuse so just it case it wont damage anything esle, does anyone know what the problem might be fo this issue?
Old Apr 23, 2016 | 10:06 PM
telum01's Avatar
You've been having problems since the guy installed the wrong part? Problem depends on what all he did...
Old Apr 24, 2016 | 12:29 PM
Arm818's Avatar
Thats the thing, he didnt install anything because the part didnt fit, and yet he claims he didnt touch anything major just disconnect and reconnected the antena wires.!!!
Old Apr 24, 2016 | 06:57 PM
//amg55's Avatar
//amg55 is infamous around these parts
Sounds like the audio shop did a hack job, dont install a bigger fuse because the problem is probably a short to ground somewhere. Check the area where he worked.
REDNOSEGT
Bentley
25
Feb 12, 2024 06:39 AM
Ronny-
May 13, 2020 03:11 PM
MrOz
Sep 2, 2016 01:45 PM
