EGR delete
Old May 3, 2016 | 08:59 PM
DetomasoGTS74's Avatar
EGR delete
Has anyone with a pre 10' MY Vantage heard of or done an EGR delete on a Vantage? My car is throwing P1488 and in speaking with Stuart earlier there may be a way to erase the code with a tune at which point I may as well delete the EGR and cover it up to prevent the exhaust gasses routing back into the manifold.
Old May 3, 2016 | 10:26 PM
telum01's Avatar
I've done it on a few other cars, and thought about doing it a while back on my '07 just to simplify things. Mechanically it should be super easy to do: pull out the EGR module and tube to the exhaust manifold. Fab a delete plate for the EGR-to-intake manifold opening and another for the tube-to-exhaust manifold opening. So long as it's tuned for it, it shouldn't be a problem. Not sure if the system can detect the missing EGR module itself (if so, you might need a resistor plugged into the wiring harness where the EGR module plugs in). Easy test would be to unplug the wiring harness to the EGR module and see if your car throws a new code for that.
Old May 4, 2016 | 12:18 AM
Stuart@VelocityAP's Avatar
Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !Stuart@VelocityAP Is a GOD !
P1488 is for your exhaust valve fuse, it's the other one (forget off the top of my head) that's for the EGR
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
Office: (1)250-485-5126
www.velocityap.com
Old May 4, 2016 | 05:07 AM
handyman2009's Avatar
Veteran: Canadian Forces
Stuart, do you mean the fuse 22 for the bypass flap ?? and why would it throw a code for that ??
Old May 4, 2016 | 07:26 AM
embdenb's Avatar
embdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud ofembdenb has much to be proud of
If you are worried about the computer throwing a code, just use a stainless steel blocking plate between the egr valve and its mounting.
This used to be the norm for all my cars until about 5 years ago when I became somewhat environmental friendly
Old May 5, 2016 | 08:44 PM
Stuart-interested in your thoughts here too. Have had no exhaust fuse since '09 with zero codes. Is this for fuse 22?
Old May 5, 2016 | 09:37 PM
I have threaded bungs to blank off EGR valves in stock, & we can do EGR delete in ECU Tune.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old May 5, 2016 | 09:39 PM
If you pull the fuse for the exhaust valves, it will store a code in the PCM - P01488. No warning light on the dash. Just notifies tech/dealer that the valves aren't working properly. Nothing to worry about.
Stuart Dickinson
Managing Director
206 Maple Avenue
Oliver, BC
Canada V2A 4W6
www.velocityap.com
Old May 6, 2016 | 10:42 PM
Thanks Stuart, so P0401 is the only code throwing the warning light and is EGR related. Appreciate your guidance
Old May 6, 2016 | 11:36 PM
Old May 7, 2016 | 09:06 AM
Stu-where does that go?
Old May 9, 2016 | 10:23 AM
Old May 9, 2016 | 10:52 AM
bunob's Avatar
bunob is infamous around these parts
Nice, I understand better now !
Old May 9, 2016 | 02:34 PM
bunob's Avatar
This is a oil drain plug ?
Could you give us the diameter and thread please ?
No warning light on the dash with this ?
Old May 9, 2016 | 02:42 PM
telum01's Avatar
You'll probably get a warning light if you don't have your car tuned to specifically address this modification.
