Bulb Failure Left Turn Indicator...
Old Jun 2, 2016 | 07:26 AM
Kapoosh1's Avatar
Kapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura aboutKapoosh1 has a spectacular aura about
Started getting this message along with the blinking of the light going fast yesterday.
At first I thought 1 of the orange bulbs in the LED strip weren't working but once it got a little darker I turned on the hazards and didn't a walk around and can't figure what the deal is. All the indicator lights seem to be working. Is it possible that one of the 7 (or 8, can't remember now) led bulbs went out? I assume I still need a whole headlight unit to fix it?
Old Jun 2, 2016 | 09:26 AM
mkzhang's Avatar
mkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud ofmkzhang has much to be proud of
for a vantage?
the LED going out seems to be a some what common occurrence. Its usually due to the circuit board, not the LED themselves. A rather expensive repair since youre supposed to get a new headlight, but a forum member has experimented taking it apart to fix. See here
https://www.6speedonline.com/forums/...rn-signal.html
Old Jun 2, 2016 | 09:35 AM
Kapoosh1's Avatar
Yes for a Vantage.
It seems like most people have the whole LED strip go out. I'll have to look at it again but at this point it seems all the lights work but i'm still getting the bulb failure on the dash and the fast blinking. When it first happened I looked and I thought one single orange led bulb wasn't lighting up, so if anything I need to see if I can just replace one bulb as the circuit board is probably fine if the rest of the strip works.
mep1811
Cayenne 958
14
Oct 13, 2016 08:34 AM
Rennen Modular
Wheels/Tires
May 3, 2016 01:09 PM
rickjaffe
Apr 10, 2016 11:24 PM
