DB9 tuning ?
Old Sep 19, 2016 | 11:54 AM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
DB9 tuning ?
Does anybody sell a tune that just smooths out the shifting and take offs from a stop?
Take offs are the most frustrating because I either lurch forward or spin the wheels and set off the traction control which annoys me to no end.
Old Sep 19, 2016 | 01:01 PM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
Check with Stuart at Velocity ap. Not sure why its lurching. The car has enough power to spin tires, so if your flooring it at take off, then the traction control will engage. But, typically tuners can mess with the TCU and maybe smooth it. Might be time for a transmission fluid flushing and change. That a lot of times will change the characteristics of how it drives.
Old Sep 19, 2016 | 01:49 PM
yvr's Avatar
yvr
yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !yvr Is a GOD !
Old Sep 28, 2016 | 08:07 PM
Irish07@VelocityAP's Avatar
Might be wise to drop by a dealer and make sure your PCM software is up to date and that your misfire factors are stored(not free, would be a service labour charge). The shift points cannot be tuned, however PCM power output can be tuned by VelocityAP. If you find the throttle still to touchy on take off's, I'm sure VelocityAp can tune the throttle somehow for you at the same time.
For tires breaking lose easily, if you have a 2007, the tires would of been expired in 2013. Have you replaced the tires since 2013? Do you have the correct size and load rating? That would be 2 main reasons for tire slippage even if they have a good amount of meat on them still.
Old Sep 28, 2016 | 09:10 PM
skeena river rove's Avatar
skeena river rove is infamous around these parts
I got the same problem. Rear tires are spinning a lot. But i am pretty sure i am the cause of it. Some how my right foot is a bit more heavy then my left
Couldn't resist
Old Sep 29, 2016 | 03:25 PM
Mitch P.'s Avatar
Mitch P. is infamous around these parts
This thread reminds me that I desperately need new tires and I'm afraid to take it to the local tire shop. The jacking points just are not clear IMO.
Good luck on your tune, I love mine from Velocity.
Old Sep 30, 2016 | 04:11 AM
SheriffDep's Avatar
Jack it up yourself, then take each wheel separately to the tire place that uses a touchless system. Have them slide on new rubber, then put back on car. One at a time, at least you wont worry.
Old Sep 30, 2016 | 10:09 AM
Mitch P.'s Avatar
Thanks, but honestly even I (pretty seasoned car enthusiast) am not 100% sure where the jacking points are. Even after looking at the video of the Vantage as well as one with the Db9 I am a bit confused. I think I'll go to my mechanic and have him show me while up on the lift.
Sep 23, 2016 01:16 PM
99Gdzra
Aug 22, 2016 11:15 AM
