Troubleshooting LED failure
Old Jan 1, 2017 | 09:39 PM
pikajew's Avatar
pikajew is infamous around these parts
Hi all, my body shop is having difficulty getting my headlights to work. I've had them modified by Oracle for my build (ADDING red LEDs but keeping OEM lights as well) and although they swear they never touched the OEM LEDs or connector, the RT headlight has the white LEDs working but not the Amber blinker, and the LT headlight has neither white or Amber working. I did get new carbon edition tails too (from AMBits) and I've heard sometimes these issues can be caused by the taillights... Before my shop sends the lights back to Oracle, does anyone have any thoughts on a fix?
Old Jan 4, 2017 | 12:36 AM
pikajew's Avatar
So I had a hunch that the taillights had something to do with it and my shop (who had installed the new carbon edition clears but apparently never tested them) just verified neither of the tails have the blinkers working.
I'm not physically there as I'm on vacation. Does anyone know if there is a special way to connect them or why the blinkers on either side don't work?
Old Jan 4, 2017 | 04:41 AM
handyman2009's Avatar
Veteran: Canadian Forces
From what I read, most time the problem is with condensations and it create a short over time. They would need to be opened and check, sorry. I disconnected my rear tail light several time and it's only one connector so it's not connected the wrong way, I haven't looked at the front yet. Do the front turn signal works or not ??
Old Jan 4, 2017 | 07:43 AM
pikajew's Avatar
So the interesting thing is that these are brand-new carbon edition tails that I purchased from AMBits. They have never been used and there is no condensation (note the 3M tape still applied for the tail lamp finishers). And although I've read that perhaps the car would need to be flashed when switching from red tail lamps to clear (but that really only applies to DB9s), I actually already had clear lamps installed (light gray trim) and just purchased these for the black trim.
None of the blinkers work on the headlights or taillights. The car has had its battery disconnected many times over the six months during the build so I'm wondering if perhaps it needs to get reset from AM? I mean there is no separate fuse for the blinkers right?
Old Jan 4, 2017 | 01:12 PM
Agaton12's Avatar
Agaton12 is infamous around these parts
Have you checked for any error codes?
Do the rear lights start working if you disconnect both front lights?
Old Jan 6, 2017 | 09:05 PM
pikajew's Avatar
I forgot to mention that most of my modules (a/c, switch plates, radio screen, nav screen, clock, and other buttons like hazard, window defogger, etc.) are still unplugged pending the carbon fiber consoles.... Consequently, the gauge cluster is blank and non-functioning. Perhaps it's screwing with the circuitry or the car's voltage and causing the blinker issue?
Old Jan 9, 2017 | 04:16 PM
pikajew's Avatar
Just saw that the Amber blinkers work when the car is locked/unlocked with the fob. And reverse lights work.
I'm thinking the no blinker issue has to be related to having all the switches/modules (including the hazard switch) unplugged??
Old Jan 9, 2017 | 06:30 PM
sdekoning's Avatar
sdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to beholdsdekoning is a splendid one to behold
You got to plug all missing switches/hardware first and foremost before you can asses any issue. As with low battery level, missing hardware will keep throwing error codes etc.
I just de-kitted my racing seats and I'm happy to be able to reset the SRS-warning light finally after 2.5 years with my Autel OBD-reader.
Don't worry at this stage: get her fully build-up and then sort all errors.
Old Jan 10, 2017 | 05:27 AM
pikajew's Avatar
Yup. Plugging in the hazard switch solved the blinker issue. DUH!
The white led failure on the driver's side headlight though remains and I'm convinced it needs to go back to Oracle to fix because all else works. 👍
Old Mar 27, 2018 | 03:12 PM
KiwiSG's Avatar
KiwiSG is infamous around these parts
This is a known issue with the AM light and prolly not anything to do with your Oracle lights
Old Mar 29, 2018 | 06:36 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
On the front LED's my old V12S (prior car) had same problem - the AM dealer ordered a kit that fixes it, so apparently Aston has a fix.
Old Mar 29, 2018 | 12:11 PM
skywagon's Avatar
skywagon is a jewel in the roughskywagon is a jewel in the roughskywagon is a jewel in the rough
My Vantage has an intermittent issue where the left front turn signal (amber LED's) will not work and gives me a warning message. The white LED's work just fine. Does anyone know what this kit entailed and any part numbers?
Old Mar 29, 2018 | 06:00 PM
cadman's Avatar
5 Year Member
cadman is a jewel in the roughcadman is a jewel in the roughcadman is a jewel in the rough
lots of info on this problem.try this link
https://www.6speedonline.com/forums/...nt+turn+signal
