What is the ideal oil level
Old Jan 26, 2017 | 10:47 AM
klmc's Avatar
klmc is infamous around these parts
So I have been having discussions with several petrol heads and there are so many opinions.
In the manual for Vanquish it states:
- The car should be on level ground
- The engine should be cold
- The engine oil level should read between the Min. and Max. marks.
SO... some say it should be exactly in the middle, some that it is not good for the engine if it is a the Max mark - as I read it as long as it is in between the marks it is fine - so even at the Max. mark it should be perfectly ok I think!
Thoughts?
Old Jan 26, 2017 | 11:07 AM
Mathman85's Avatar
Mathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to allMathman85 is a name known to all
Is the Vanquish wet or dry sump? (I know the V8s are dry, not sure about the V12s.)
On a wet sump engine, going above the max line can increase windage on the crank, which will prematurely wear bearings. I'd aim for somewhere in the middle, on such an engine.
On a dry sump engine, anywhere between the marks is fine, though I'd cautiously avoid the "min" mark.
Old Jan 26, 2017 | 11:20 AM
klmc's Avatar
Seems that DB9 and Vanquish are both Dry Sump
http://en.aston-martin-club.com/arti...2-engine-s-106 (can't find any information about the 2016 Vanquish)
but found this.. "a new oil pump and redesigned “high efficiency” wet sump - new pistons, valves, springs and even the cylinder block has been revised."
Old Jan 26, 2017 | 11:47 AM
XJRS Owner's Avatar
Wet sump. Mid to Max OK. Add 1Q/1L if at Min. Always check only when cold (no sooner than 10 minutes after shutdown)
Old Jan 26, 2017 | 01:16 PM
klmc's Avatar
Thanks - happy there is a reason for the min. and max. marks afterall - so at the max on a cold engine is fine then!
Old Jan 26, 2017 | 09:10 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
On a side note, always err on the side of caution, engines on ANY car hate to be over filled.
Old Jan 27, 2017 | 11:51 AM
klmc's Avatar
Thanks - will make sure it is below Max
Old Jan 28, 2017 | 08:18 AM
captain Greg's Avatar
captain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to beholdcaptain Greg is a splendid one to behold
Just for clarity cars that have dry sump and oil tank is it ok if they carry a bit extra? Looking into the stainless tank it seems it does have space for expansion when the oil is hot? Or is it crucial to have it exact? I understand about cars with a sump.
Old Jan 28, 2017 | 06:00 PM
embdenb's Avatar
I think you are overthinking this. The oil tank must have some free space as the hot oil returns to the tank from the engine. Do not overfill. As others have stated, keep the oil level between the min and max marks on the dipstick and worry about something else. (Smile)
