15mm front spacers for Vantage?
Old Feb 10, 2017 | 05:33 PM
OnyxVantage's Avatar
OnyxVantage is infamous around these parts
Originally Posted by Zettinger
Just checked my older posts.
Front: H&R TRAK Spacers (2265681CR)
11mm for the front come with own nuts to replace the originals.
Bolt Pattern: 5/114.3
Bolt/Stud: Stud
Center Bore: 68.1
Thread Type: 14x2.0
Width: 11mm
Rear: H&R TRAK+ Wheel Spacer DRM Style 4665681
23mm for the rear have studs on the spacer (DRM) to use OEM nuts.
Bolt/Stud: Stud
Center Bore: 68.1
Thread Type: 14x2.0
Width: 23mm
Hi, is it true that you have to shorten the original rear studs to install the 23mm H&R spacers?
