Sport button
Old Mar 8, 2017 | 01:21 AM
rohnin's Avatar
rohnin is infamous around these parts
Sport button
Kind of a dumb question but is it ok to press the Sport button (and trac off) while accelerating? Or is it better to switch modes while idle?
Old Mar 8, 2017 | 01:29 AM
sanengo's Avatar
sanengo is infamous around these parts
Yes you will notice the immediate throttle map change with the throttle pressed so make sure you arent surprised by the sudden acceleration.
Old Mar 8, 2017 | 02:10 AM
SheriffDep's Avatar
SheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to allSheriffDep is a name known to all
The sport button on ANY Automatic---- The button changes the pre-set shift points on the transmission (however under full throttle nothing changes either way; so if your in non-sport and you mash the throttle, you will get the same power output and shift points as in Sport Mode)
IN some vehicles the throttle sensitivity changes some, and in most sport cars the exhaust flaps open up sooner or stay open all the time. Depends on manufacturer.
Not a dumb question---- most people don't know exactly what the button does, such as the AM salesperson telling me to hit that button and I will have more horsepower and the car will be faster. Good selling technique for an idiot.
IF I am wrong anywhere in this posting, I am open to the specifics of AM's on this, but it will do nothing to upset the balance or drivability of the car.
Oh, forgot one thing----- cars with automatic suspensions, air bags etc.... the button will typically tighten up the suspension damper settings also. Not sure if later model or new model AM's have them, don't thing so but could be wrong on the Vanquish, DB11 etc...
Old Mar 8, 2017 | 03:08 PM
rohnin's Avatar
Thanks for the responses! I have a manual, so I assume pressing it while accelerating will just make it louder and faster For some reason I never used it unless ready to go at a stop.
Old Mar 8, 2017 | 04:47 PM
deckman's Avatar
Not faster just louder
Old Mar 8, 2017 | 07:11 PM
randyb's Avatar
randyb has a spectacular aura aboutrandyb has a spectacular aura aboutrandyb has a spectacular aura about
On my DB9, not louder or faster in sport mode. In my opinion the sport button is a waste, the ecu keeps the car in a lower gear and seems to shift at the same rpm as non-sport mode. Does not allow car to go into 6th gear at higher speeds which is just dumb in my opinion.
Old Mar 8, 2017 | 07:35 PM
SheriffDep's Avatar
Manual? Like the book?
NO it doesn't make anything faster. If you have the throttle maxed, the valves for the exhaust are open above 3k anyway, so it wont make the car louder either.
Your throttle shift point under regular throttle are changed, to a higher RPM.
Like was mentioned, it also prevents 6th gear usage.
Your car has 450hp or so stock. That power is available at any time by the push of your right foot. The sport button does not make your car all of a sudden have more HP. IF the exhaust is not affected by the Sport button on the DB9, then the button for all intents and purposes worthless IMHO. That would be the only reason for it, in real world driving. Its a gimmick.
Old Mar 8, 2017 | 09:27 PM
ncamv8's Avatar
ncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to allncamv8 is a name known to all
Personally I like the throttle mapping changes that sport makes.
With a manual car, I'm much less likely to stall in reverse, since sport mode makes the throttle more sensitive / rev sooner.
As stated before, on the manual vantage, sport mode changes the throttle mapping and opens the exhaust flaps sooner. That's it.
I wish the manual cars had a setting to default sport mode on, like the sport shift cars do. as it is I always reach over and press sport after starting the car.
Old Mar 11, 2017 | 02:13 AM
rohnin's Avatar
On my 2016 MT, there is a way to make sport default on.
Anyway I think most misunderstood my question - just wanted to know if it was ok to press the sport button while accelerating on the throttle
Old Mar 11, 2017 | 12:00 PM
Ron Avery's Avatar
Ron Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to beholdRon Avery is a splendid one to behold
I have a 2016 Vantage GT, I have looked in my set up menu and owners manual. The option to have the sport button set to default on is not shown. I was told it is not on the the USA cars, only outside the USA by my dealer. Very odd.
Ron
Old Mar 13, 2017 | 11:41 AM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
On my SportShift 15 GT my Sport Button is always on once I press it - on my buddies 14 Vantage it does not stay on. It makes a huge difference in driving enjoyment with the SportShift, likely not so much with a manual, but the sound is nicer.
