Auto folding mirrors stopped working!
Old May 29, 2017 | 08:05 PM
goto35's Avatar
goto35 is infamous around these partsgoto35 is infamous around these parts
08 Vantage roadster. Came from my long trip started up car. Top wouldn't work. And when opening door window wouldn't roll down slightly. Did some research and windows needed to be reset (down hold 5 seconds up hold 5 seconds)
Anyways top started working but auto filing mirrors still not working. Maybe I didn't reset windows properly. Does car need to be on or off? Door open or door closed?
At first I thought it was too modified but maybe not?
Old May 29, 2017 | 09:01 PM
Timodc's Avatar
5 Year Member
Timodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to beholdTimodc is a splendid one to behold
Unfortunately, you'll need an AMDS to set the mirror fold function on a 08 and earlier model.
Old May 29, 2017 | 09:15 PM
goto35's Avatar
Thanks. So this happens that it just looses the auto folding memory?
Old May 29, 2017 | 09:23 PM
Timodc's Avatar
5 Year Member
Typically this happens during a low voltage event. Has the battery been low or dead lately?
Old May 30, 2017 | 11:55 AM
goto35's Avatar
car sat for over 2.5 weeks. there was hesitation when starting. Battery was probally low. (Alomost been 5-6 years since last battery change).
So yea probally the battery. Wonder how much a dealer will charge me for this.
i miss the auto close feature a lot!
Old May 30, 2017 | 12:41 PM
Timodc's Avatar
5 Year Member
Where are you located?
Old May 30, 2017 | 12:45 PM
goto35's Avatar
Los Angeles
Old May 30, 2017 | 12:46 PM
goto35's Avatar
Also what's the best way to get battery checked out? Autozone?
When do I know it's time to replace battery? Might even be on the original battery.
Old May 30, 2017 | 01:57 PM
embdenb's Avatar
Car sat for 5-6 weeks, hesitated starting, battery is 5-6 years old?
You might not know when to change the battery, but your car knows
Change the battery
Old May 30, 2017 | 02:42 PM
goto35's Avatar
Change the battery
lol yea your right. hesitation is only when car sits for a few weeks. But after first drive its usually ok. but might be a good idea to change battery anyways.
Old May 31, 2017 | 12:09 PM
davidm17's Avatar
5 Year Member
davidm17 is infamous around these parts
Most auto parts stores can test the battery, but you'll likely have to pull it out for them to test since it's inside the car behind the passenger seat. They might be able to get to it with it still in the car, but if it's 5-6 years old you might as well plan on getting a new one. It's a fairly straight forward DIY with a good write-up on Redpants' web site. The only gotcha is you'll lose any sort of memory settings when the battery is out of the car. You could get one of the memory tenders that you can plug into the 12v power outlet that will maintain the memory while you swap the battery. If you've already lost the memory setting then that may not be an issue. I've gotten in the habit of keeping vehicles I don't drive every few days on a battery tender. Prolongs the life of the battery and keeps you from having weird electrical issues.
Old May 31, 2017 | 12:15 PM
goto35's Avatar
Thanks! Do you guys know how different it is to change the battery on the roadster?
Old May 31, 2017 | 12:54 PM
07sportspack's Avatar
07sportspack has a spectacular aura about07sportspack has a spectacular aura about
Astons hate any battery that is not in solid performance condition. So many time there are posted problems directly or indirectly related to the poor condition of the car's battery battery. The battery change out procedures are noted in the FAQ section. My comment is to have the right tools AND be patient...it's a little tricky. I keep my battery on a trickle charger and change the battery every 3 years here in HOT weather Florida. The last time the store exchanged it free as it tested below "very good". I have been lucky not to lose settings when I swapped batteries. Good luck with your change out !
